Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Will a burned out defrost heater cause the refrigerator section of the side-by-side Frigidaire to stop cooling? I have relpaced both the thermostate and the defrost control. Frige still not cooling/freezing.
    President:
  • 1,218 Answers
Good day,
Only if there is a build up of frost on the evaporator coil behind the rear panel in the freezer section.
I don't know what thermostat your describing, but the one controlling the defrost system is mounted on top of the evaporator coil. it looks somewhat like this.
It must work. It can be tested with an ohm meter as long as it is cold. It should read zero ohms. As well the main heater can be tested with a meter. It should read 35 ohms or less. If either one tests bad, replace.
Once again, this approach is only for a situation where the evaporator coil is iced up. If not......
Other causes could be the fan motor not running. It is in the same area.
Lastly, there is a motorized damper located in the top left side of the fresh food compartment. It should be throttled open to allow cold air into the food compartment from the freezer.
Posted on May 06, 2010
Top freezer works but main frig does not
The way a refrigerator / freezer works is a single cooling coil in the freezer controlled with a thermostat. There is a fan that blows cold air down into the refrigerator section. There is another control that is just a vent control that changes the size of the opening for air flow. if the fan fails you don't get good cooling in the refrigerator section or if the defrost is not working correctly ice will build up and also stop the flow of air to the refrigerator. You should be able to hear the fan working inside the freezer. Replacing a fan motor is much simpler than troubleshooting an icing problem. There are several components that can cause defrost to not work. Bad temp cutoff switch, defrost timer or heater element could be causing that problem. With the unit unplugged and heater element disconnected you can use an ohm meter to measure resistance of the heater, should measure some resistance. Same with cutoff you should measure resistance when cold and none when above cutoff temp. Room temp is well above cutoff and use ice water to see if it closes.
Dec 13, 2013 | Frigidaire FRT21S6A Top Freezer...
The freezer gets very cold, but the bottom where the milk and vegetables does not get cold.
One of two things has happened. Either your evaporator fan has stopped working and not forcing the cold air down the cooling tubes to cool the refrigerator or the cooling tubes have iced up and the cold can't get to the refrigerator side of your unit - which is generally a defrost circuit malfunction.
If you don't feel air flow in the refrigerator section, then I am on the money. First check the fan and see if it is turning, if not replace. If it is turning, then you will need to use a hair dryer to defrost the dreezer and air tubes. Then troubleshoot the defrost circuit which is normally made up of a defrost heater, defrost thermostat and defrost timer.
Jul 13, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
I have a model gss25lgmb bb. Im having issues with (couple of months) my fridge randomly stop cooling. Causing everything to defrost. My fan still seems to be on but not cooling or freezing. PLEASE HELP
If its not cooling or freezing then the compressor has to be checked.The compressor is the part which controls the cooling and freezing in the refrigerator.If the gas / refrigerant in the compressor gets low/ less then compressor will run more but it will not cool due to less refrigerant in compressor.In that case the compressor needs to be replaced. -------------- Also it can be faulty defrost assembly parts causing this issue.The thermostat is got faulty or the heater is not turning off.This also causes every thing to get defrosted.
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------
Before that you can try manual defrost reset procedure. The manual defrost reset procedure is as follows : ----First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again.Then go for replacing the parts.-------------------This should help.Thanks.Helpmech.
Apr 06, 2011 | GE GSS25LGM Side by Side Refrigerator
Freezer side gets very cold, but the refrigerator side is slightly cool. Replaced thermostate but the results are the same.
It may be a defrost issue. If the freezer is not defrosting then ice encases the fan motor behind the back wall of freezer and wont allow it to circulate the cold are to refer section. To see if that is the issue check behind the freezer back panel if it is iced up try unthawing it, have towels on the floor it will make a mess, if it starts cooling again after you thaw it out then you know its a defrost issue and it will work until the ice builds up again. You may need a new defrost tstat, heater or timer.
Oct 13, 2010 | Whirlpool ED5THAXMS Side by Side...
Side by side refrig. side not working;freezer freezing up
The unit is not defrosting. Either the defrost clock is defective or the defrost heater is not working. Defrost clock is normally located behind the bottom kick panel. Use a large standard screwdriver and turn the center screw clockwise very slowly until the compressor stops. Wait 20 to30 minutes the compressor should restart, if not the defrost clock is defective. Checking rhe heater you'll need a vom meter or amp meter.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator side is not cold.
If you have frost on the back wall of the freezer you have a defrost system problem which in turn is reducing the air circulation for cooling the refrigerator or stopping it completely. What your brother said was close to the truth of the matter. If you have a defrost problem it is one of three things that will be the cause. Defrost timer, defrost heater or defrost thermostat.
Jun 01, 2008 | Kenmore Refrigerators
Refrigerator side not cooling - freezer side icing up
It sounds like your defrost system has failed. There is a timing device that turns on the defrost heater(s) which may have stopped working. Or the heaters or defrost thermostat could be bad.
My suggestion is to find a different repair person who is qualified.
May 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Burning smell from frigidaire side by side black
there is a defrost heater inside the freezer section, remove the back paanel from inside the freezer. lookin at the evaporator the u-shaped black heate wraps around under it, there are some peices of styrafoam( used for air flow) surrondin evap area, make sure none are hitting against heater assy
Feb 25, 2008 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
219 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
