Question about RCA P56812BL 56" Rear Projection Television
The picture is just kind of blurry. A little
The picture is just kind of blurry. A little dark. Just not clear. It may have been in storage for quite some time before it came my way.
  • RCA Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/41128/SONY_Projection.html
You may need to clean your lens on your projector, but also i may just need to be used for a while, and it may "Come back" You see when electronics are left without any power going through them, it can, and does have a deleterious affect on any unit. Things called Electrolytic capacitors, need to "Form" this happens when the current flows through them, and they build up an oxide layer, and work as they are meant to. Now when, there has been no electricity flowing through the capacitors, the "Dry Out" loose their oxide layer, and, if left long enough will go so faulty, as to often prevent the unit from working, properly or even, completely. So there is NO doubt there is a component in there that applies to your set. You need to leave it on for about say, 12 hours straight, if it isn't OK, after that, then you are going to have to troubleshoot, and possibly adjust the convergence and focus setting, as per the manual. www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
http://www.eserviceinfo.com/index.php?what=search2&searchstring=J52A+(projection)
http://myweb.accessus.net/~090/how2adj.html
http://www.pdfee.com/search/Toshiba%20rear%20projection%20training%20manual
Those links above will assist you. They are Projection TV training manuals, so you can get to grips with what to do.
Posted on May 06, 2010
DLP television picture not clear (blurry) and dark.
Hello
If picture is dark in DLP TVs, its lamp should be taken care of. In some lamps, the reflecting side coating of lamp will be bubbled, preventing sufficiant light to fall on DLP chip. Replace the lamp if necessary. Check it first, taking it ouside. OK.
Apr 15, 2011 | Mitsubishi Televison & Video
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
Is there any way I can clear up a blurry picture on this camera once the pic is already taken?
On TV shows, they can take a blurry picture and enhance it to crystal clarity. In real life, however, those kinds of miracles aren't possible. In a photo editing program like Photoshop Elements, you can bring up the sharpness a little but you eventually reach a point where the picture no longer looks like a normal picture. The slogan is "garbage in...garbage out"...meaning you can only do so much to what you have to work with.
Dec 07, 2010 | Panasonic Lumix DMC-LS75 Digital Camera
Picture comes out dark
Reset you cam settings: Take the batt out for longer than 10 sec and reinsert them.
Find a link between the SCN that are dark and blurry and the ones that aren't. Is it when using flash taking pics outside or inside in certain modes etc.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
May 19, 2009 | Cameras
Easyshare C713 LCD view is flushed out.
you push on the little 'i' button thats right under the delete button.
May 14, 2009 | Kodak EasyShare C713 Digital Camera
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
Blurry pictures
try having other people take a picture with your phone, if they can take a more clear picture, it is likely that you are just a little shaky when taking pictures (i have the same problem)
Jan 31, 2008 | Motorola Mobility L6 Cellular Phone
Digital camera
you can try and adjust the contrast for that pictures. try also iso 300 for the picture to increase quality. downpoint is its size will increase. just explore the settings and try them all out. im sure you will find the perfect settings that you'll like
hope this helps.
fixya!
Jan 31, 2008 | Cameras
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Televison & Video Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
