Recognize the new mother board?
I have a PC which pre-installed Vista on a partition when I bought, (I do not have Vista disk). The question is if I replace a new motherboard, will Vista recognize the new mother board?
  • 20 Answers
Before you install the new motherboard make sure you have all of Windows updates installed on the hard drive. Microsoft is working hard to include many new devices all the time. You should have no problem booting into Vista after the motherboard is intalled and your motherboard should come with a driver disk to install any drivers that Vista may miss.
Posted on Mar 27, 2008
HP Pavilion TX1000 Series with new 500 gb hdd unable to install windows 7, after partitions on hdd, it disappears, and unable to install os
not sure what "after partitions" means. (ah, at that point in install)
dual booting?
HP disk set
or Microsoft set.?
tell what attempting and where stuck exactly.
what screen , and what error exactly.?
new 500, new in box, new to your or new for an APPLE.
if new, really new it has mfg codes on box for any special pre-formatting...
i bet the new disk is pre-formatted. (or really not new)
seen many new disk in box with antistatic bag breached.
bingo , not really new.
what disk ,? Seagate (best)
windoz hates that, (setup.exe running)
erase the new 500
3 ways.(lots really)
1: put new 500 , as a 2nd HDD in PC #2,
2: with disk-manger delete all partitions on it. its now ready.
A: using boot windows, PE disk, do same in this PC.
B: using boot cd, boot and go to repair mode,(first screen)
then using CMD prompt mode, use DIskpart, to do that.
C: using any bood Linux, live CD same PC, run pparted and erase the partitions.
I can go more, but stop.
All windows install disk, cept w10?>
will erase any windows partitions (if you force it)
but will not do it if the format is ALIEN to MS.
Alien means not fat 16 , Fat 32/ NTFS,
Alien means Apple or other 100s of systems alien to MX.
on windows 10, it will balk with any data there what so ever.
protecting the NOOBs. cure is above.
Apr 11, 2017 | HP Computers & Internet
I've updated the BIOS but still can not get the mother board to consistantly recognize a new 1T Hard drive. It works once, but when I reboot it corrupts the Windows XP and the recovery partition.
Can you temporarily attach the "new" disk-drive as a "slave" disk-drive in some other computer?
Then, write some files onto the disk-drive, restart the computer, and see if the files are corrupted.
If they are, then the disk-drive is defective, and can easily be replaced, under warranty,
either from where you bought it, or directly from the manufacturer.
If the files are OK, then it's your motherboard that is the problem.
Dec 08, 2010 | ASUS P4SDX Motherboard
Installation of windows vista
Follow below steps
1. Insert the Windows Vista DVD into the DVD drive in your computer and restart the system
2. Before booting up again, Press F2 or F8 depending on the type of mother board you have or press the button as per the bootup display to open up the boot menu.
3. select the DVD drive at the boot menu.
4. Now the Computer will boot from the DVD with Vista OS.
5. Go for the Custom install option and select C drive for install. or if there is no partition available, the disk can partitioned there itself.
6. folow the wizard and here you go. Vista is installed in your system now.
Hope this helps. :)
Aug 06, 2010 | Microsoft Windows Vista Ultimate Edition
My hp compac come on powers up, but will not go on line, will not recognize the disc drive , will not recognize any USB ports and when I go to shut down, it will sit on the "shutting down" screen for...
just a mobo huh, no PC, there.
so what PC did it come out of???? HP what? desktop .
turns on, ok
will not recognize the disk, (what disk? what drive, what disk,??)
floppy, PATA HDD, SATA HDD, or CD drive.?
will not recognize, USB ports. (in BIOS or in Tne OS)
what OS, windows 3.1? what/? what Operating System??????
what OS will not shut down, and installed by whom and what media>?
take this unstated PC and install the OS, as it came new.
This PC is so old its not supported by HP, now.
so find and install disk (media) and re-Install the OS.
there it is, Google fails to find the match to any HP PC model name.
HP has zero data on it, now, its too old.
Jul 13, 2017 | HP (D7580-60003) Motherboard
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Cannot reformat computer; no partition
the H drive is the manufacturer restore drive..where the factory setting, Driver and OS are installed ..since you deleted the drive and wanted to install new vista.
since you are using the OEM disk...boot your computer from custom install...if u are in stage that asking which drive are you going to install the more drive options in lower right...then create partition ...format..then install
Mar 16, 2009 | Gateway MX6920 Notebook
Compaq Presarioe A900
Webcam driver probably did not install properly.
Go to Device Manager. Unistall the Webcam. Reboot.
Vista will scan for new hardware, locate the Webcam and reinstall the driver.
Good luck.
Jan 15, 2009 | Compaq Presario Notebook
Can't get NEC Litepad to recognize new Toshiba 1.8" MK2004GAL
I've read on other web forums that the recover disk only works with the original drive partiions. There's a hidden partition on the original drive that the recover disk uses to install the OS (maybe other software too). You'll need to clone/copy the original disk partitions to the new hard drives and then you'll be able to use the recovery disk.
Nov 28, 2008 | NEC Versa LitePad PC Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
