Question about HP Pavilion dv7-1020us Notebook
HP dv7 simply stopped turning on. worked great
HP dv7 simply stopped turning on. worked great one day, woke up the next to find it would not power up. It was plugged in all night so I presumed charged. tried removing the battery & unplugging the power but still nothing. when i hit the on button the light on it come up for about 10 seconds and when the power cord is connected the charging indicator light is on. Thats it. someone please help me. My company is on this thing. of course i called HP and i am exactly 10 days out of warranty. too funny.
    Scholar:
  • 91 Answers
What you would want to try is to remove the battery and see if pluging in the power cord will power the laptop alone. All laptops have this capability and this shouldnt be an issue.
But by testing this and seeing if it DOESN'T work then that means there could be one of two things. Your AC power adapter is defective and should be replaced with one that is compatible with your system or that your connection jack is either loose on the inside or broken completely.
However I would stick with trying the cord first before trying to resoder the joint inside the system. I'd leave that to a pro, going back to the battery if you leave it out for a day that should give it plenty of time to discharge any energy it may have in it and you can plug it back into the laptop to try and charge it again either with the same AC power adapter or a new one. If the battery wont hold a charge and you know it isn't because the jack is loose or the AC power adapter isnt defective then you now know you need to replace the battery. You can google compatible batteries and power adapters online or search specific places like Newegg.com or Amazon.
Hope this gives you a better understanding of what may need to be done to fix this!!
check me out at http://ctrlr4repair.webs.com
Posted on May 06, 2010
How would I now if the battery is bad
Hello rrodri4330,
Welcome, and thank you for using FixYa!
To answer your question: The laptop itself will tell you that the battery is bad.
In any version of Windows, when you look down near your clock, you should see the Charging Icon engage and display; once the power adapter is plugged in. While this icon is displayed, you should see the percentage number rise, as the battery charges. If the battery remains at a low percentage, and never rises, then the battery is bad. That will be proof of your need to replace it.
I included a link below, from eBay!, to where to can purchase a replacement, cheap.
Battery
http://www.ebay.com/itm/8-Cell-Battery-HP-Compaq-Pavilion-DV7Z-DV7-1014TX-/250827506356?pt=Laptop_Batteries&hash=item3a667c02b4
Have a great day!
Sep 20, 2011 | Pavilion Laptop Battery For HP Pavilion...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Replace power supply cable
The part number for the replacement AC Adapter is HP Part # 609940-001. Here is a link to HP's website where the item is located, and you could buy a replacement directly from them.
Thanks, and have a great day!
If my solution helped you, please don't forget to leave positive feedback!
Sep 18, 2011 | HP Pavilion DV7-1232nr Notebook
One of my usb ports won't work properly. If you plug something to it for longer than half an hour the usb port stops recognizing the device you plugged. I have an hp dv7 4190us laptop.
Start with the normal fixing methods, including uninstalling the drivers for your devices and reinstalling them. if That didn't work! Next try System Restore thinking that maybe you have installed something and it caused a conflict with the USB system drivers. That didn't work!
go to Device Manager and uninstall all of the devices under USB Controllers. Restart the computer, reinstall the USB drivers,
You may also see in Device Manager that the device shows up as an "Unknown Devic
last fix for the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Jan 10, 2011 | HEWLETT-PACKARD HP Pavilion DV7-4190US
My HP DV7 laptop will no power on. The LED next
try pulling the hard drive loose and see if it tries to boot and comes up with no boot device found if it does the hard drive is bad if not the bios is corrupted and will need the bios reflashed.
May 08, 2010 | HP Pavilion dv7-1130us laptop
I have a HP Pavilion dv7-1232nr, the mute button and the wireless button on the top touch pad has quit working along with the volume slider. Any suggestions?
My mute button on my hp pavilion dv7-1262us stopped working after I updated my IDT High-Definition Audio CODEC through Microsoft update. The volume worked but the button stayed orange. I went to Device Manager- Sound,video and game controllers then IDT Audio CODEC. Click the Driver tab then click the Roll Back Driver button. This rolled the driver back to an older version but it fixed the problem. This is a Vista machine. Hope this helps.
Mar 06, 2010 | HP Pavilion DV7-1232nr Notebook
HP DV7-1267cl laptop - Keyboard and Mouse Problem.
go to the link http://h20180.www2.hp.com/apps/Nav?h_lang=en&h_cc=us&h_pagetype=s-002&h_product=3878252&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us&submit=Go%20%BB#___sp and select your operating system.after this look for bios and click on Winflash for HP notebooks and download it to the desktop.once download is done go to the desktop and run the application and follow the wizard by clicking next and continue.this process will automatically shut down the system.turn it on and if everything goes well your system should work fine.
Jan 24, 2010 | HP Computers & Internet
HP L1906 Flat Screen Monitor Power Light Flashing
http://www.fixya.com/support/t558081-monitor_will_not_power
Jun 01, 2009 | HP L1906 19" LCD Monitor
Linksys wireless not connected to my mew HP pavioion laptop
Linksys wireless have know to go bad, return and try another one.
Nov 17, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv7-1020us Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
