Question about Dell (0F146) Internal DVD Drive
Dvd drive does not read - Dell (0F146) Internal DVD Drive
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
What is the advantage of having a super multi dl drive
This drive recognizes almost all formats of CD & DVDs available in the market
The drive can read and write the following media
1. Write CD R / CDRW / Read CD , CDR, and CDRW
2. Read & Write DVD +R, DVD -R, DVD +-R, DVD RW / Dual layer DVD.
Normal drives will be specific to only DVD +R or DVD -R or single layer.
Jan 27, 2011 | Acer (KV.16X04.007) DVD Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
My dvd drive doesnt reconise disks when they are in the drive
2 things that u have to check
1) Is your DVD disks damage so u cannot read it?
2) Is your DVD drive spoil so cannot read your DVD?
To check condition 1), u may try insert other "good" DVD to make sure your DVD drive may read it. If your DVD drive can read other DVD so this mean your current DVD disks are damage.
To check condition 2), u may try load your DVD disks using other laptop. If your DVD show readable on other laptop, then this mean your current DVD drive is spoil or may have poor lens sensibility. Try to clean your DVD drive or replace a new 1 if necessary.
YBC (/\)
Oct 02, 2009 | Acer Aspire 3050-1733 Notebook
I can read data cd but cannot read data dvd
Are you sure that the drive you are trying to read the DVD with, is actually a DVD drive and not a CD drive? Check on the front of the drive draw, it should say DVD on it. If not you will need to purchase a DVD drive to read DVD's. Nik.
Jun 30, 2009 | Computers & Internet
LG DVD drive stopped reading DVD's
Try re-installing the drivers. If that doesn't help get a new drive. Optical drives are one of the first things to break in a computer. Of course make sure everything is connected properly.
Dec 05, 2008 | Computers & Internet
Problem with sony dvd rw aw-g170a
Hi i have Sony AW-G170A on 2 pc's and almoust at same period both pc's started not to read DVD cds, cds that were writen by the same drive so ive check the net and end up updating the Firmwares 1.71 to 1.75 so check this link. And get AW-G170A Firmware 1.75 then u gonna need Binflash to update the Firmware get Win32 GUI version if u use Win Xp. Open the program press Flash find the location of the 1.75 Firmware and update it restart pc and it should work it worked for me.
Jul 31, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to ka_s5@hotmail.com
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Oct 31, 2007 | Computers & Internet
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Dell (0F146) Internal DVD Drive Logo
91 people viewed this question
Alun Cox
