Question about Endurance TF3i Folding Treadmill
Hi There, My treadmill is a BH pro fitness Explorer G636. Recently the rubber from the front cilinder started to break apart. What does this means!? Too much lubrification, belt too tigth or is it the age (has 7 years of domestic use). Thanks in advance. Regards, Pedro Pereira
    President:
  • Endurance Master
  • 832 Answers
Actually it means you have been a avid user of your unit.
Unplug the unit remove the motor shroud, then go to the end of your unit I believe it uses an allen wrench loosen the belt. Now while at this portion count how many times you have turn the bols son each side then write it down so when you are ready to apply the same tension you be in the ball park. Now what you need to do is actually see if it is the front unraveling or it is the running belt. then that said done call BH and order the part or parts needed complete the repair or ask them if they have a reliable servicer in the area to complete the repair for you.
Posted on May 06, 2010
Testimonial: "Ok it is the front cilinder rubber that is getting loose or broken ... The back cilinder does not use any rubber and the running belt is ok. But still i am not shure if this was caused by its use. I think this rubber is needed because the motor needs some kind of contact between the running belt and the cilinder. But i didn´t use it so much in order to tear the rubber apart..."
BH Pioneer pro Motor won,t run more than few seconds Error 1 showing cuts out reset does not do anything
cad8d0f1-568e-4bca-aef5-30bf8d5e41c0.gifsee the video attached and proceed according. lube the rollers bearing front+back too.
2) Run the software calibration for easy diagnostic and fix it.
3) See the diagram attached for s. sensor.
4) See my personal TIPS for help
God bless you
Oct 22, 2013 | Bh Fitness TS2 Folding Treadmill
Owners manual BH Fitness G6448N
Check your mail. I have sent you the manual for your treadmill.
Ajin
Apr 26, 2012 | Exercise & Fitness
Instruction manual
Hi, please can anyone help. Looking for owners manual/user guide for a BH FITNESS PIONEER PRO (PART NO G6448N) Treadmill,
Please email me ell-jay@hotmail.com
Thanks
Aug 08, 2011 | Bladez Fitness BH T8 PRO Treadmill...
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
How to choose Stabilizer
how to calculate the stabilizer rating for my new BH-6446E tread mill
Jun 04, 2010 | Bh Fitness G637 Explorer Evolution Folding...
Hi. I have a BH Explorer treadmill. We recently moved it to another house. When I connect it and switch it on, the display goes on. I then insert the key, but the treadmill refuses to move. I have tried...
By the sound of it I am assuming the you have power to the upper display. This happens quite often when people even moving their treadmill from one room to another. My suggestion is first make sure that the safety key is engaged on the upper electronics if it is then, unplug unit remove motor shroud then locate lower board and pull and reconnect each connectors then fire it up and observe if the LED lights are on one will say PWM. This is the command for the motor to engage, the light will start flickering this mean the upper console has sent the proper signal for the motor to move. If no movement then unplug unit then remove the two connectors that go to the motor attach a 18v dc (fully charged ) drill battery and if you the motor move then look at the lower board by sheer bad luck went bad . Now if you see no flickering on the lower board remove upper console and check the the connections their. hope this give you a directions to follow.
May 17, 2010 | Bh Fitness Exercise & Fitness
Bh home running treadmill belt
Contact number for BH Fitness
Customer Support
Domestic (U.S. and Canada)
T: 949.206.0330
F: 949.206.0013
Apr 20, 2010 | Bh Fitness T8 Basic Treadmill
Endurance TF3i Folding Treadmill Logo
128 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
