Question about MSI K8MM-V Motherboard
My computer cant detect my mouse! but in my 2nd restart its ok!
  • Ctrlr4repair
    Ctrlr4repair May 11, 2010
    I need to know a little bit more about this before I can give you a definite answer. I need to know what type of mouse either wired, wireless, or usb wired. As well as what you mean by the 2nd restart it does? Does that mean you have to restart your system in order for your pc to recognize your mouse?
  • 326 Answers
Is it a usb connection or ps2? if its usb then you would be better buying a ps2 connector block for around £2, ive had problems trying to format a machine once that wouldnt pick up the usb keyboard until it booted to the desktop.
Posted on May 06, 2010
How do I use mouse instead of touchscreen on Samsung laptop
Do you have a mouse connected by cable or a USB dongle? If so, then your computer's Plug and Plug (PnP) capability to detect, install and activate peripheral device drivers will have recognize the mouse and made it accessible to you. If the mouse in not usable, look in Start, Computer, System Properties, Device Manager, Mice (etc.). If you have a Yellow Triangle, click on the mouse then the Driver Tab to Update the driver. This should solve you problem. You may have to Restart to gain access. If that doesn't work. Unplug the mouse connection, Restart the computer, then plug the mouse connection in again. Watch to see if PnP detects the connection and installs it.
Sep 20, 2014 | Samsung Computers & Internet
How do I replace myDell mouse with a new GE mouse
Close the system down, remove your old mouse and fit the new one and restart your computer. It should detect the new mouse and work, or it should say new hardware detected.
Feb 01, 2014 | Computers & Internet
Cant detect by my computer
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 28, 2011 | A4tech Wireless Optical Mouse rfsop-48
Keyboard doesn't work. mouse is ok battery new
You say the mouse works OK. You also said the battery is new--I take it you are talking about the keyboard battery.
1. Is the keyboard battery installed correctly?
2. Have you pushed the "connect" button on the USB antenna?
3. Have you pushed the "connect" button on the bottom of the keyboard?
If you have done these 3 things, you should be up and running. If not, you might go into the device manager and delete any keyboard there and try restarting the computer to see if the keyboard is detected.
Oct 07, 2010 | Inland Pro Keyboard
Computer does not detect mouse
You could try putting the disc in the drive and then RIGHT click on my computer icon the disc should show in drive D right click on it an open it , find the installation part . install.
May 17, 2009 | Computers & Internet
When I restart my computer It does not detect the keyboard/mouse
Sometimes, USB Keyboard and USB Mouse give such problems. Try using conventional (PS/2) Keyboard and Mouse.
Mar 29, 2009 | Computers & Internet
About detection of mouse
Try restarting your computer with your new mouse installed.
Jan 19, 2009 | IBM MSI MS-6188 (49P3492) Motherboard
CURSOR STUCK ON COMPUTER SCREEN
try to reconnect the cable properly.make sure its well fitted to PS/2 port that it will not tend to loose. Then, restart your computer.if its not detected still,go to control panel then click add hardware wizard then detect the the mouse if its working or not.ok?
Jan 25, 2008 | Microsoft Trackball Optical USB PS/2 Wheel...
Detected before, but not after. Help me please,
Go to device manager and uninstall everything under the USB heading and restart your computer. This should reinstall all the drivers and hopefully reinstall your mouse. You may need to rerun the driver you downloaded for the mouse afterwards.
My next suggestion your be to try the mouse on another computer to make sure it is not defective.
Jan 15, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
MSI K8MM-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
