Question about Konica Minolta bizhub 250 All-In-One Laser Printer
I have a Bizhub 250 printer that I want to set it up on a network. How can I assign an IP address to this printer?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Press Utility/Counter key
Select Admin
Enter Password 12345678 or 00000000
Select Admin 2
You will find network settings there.
You can also download user manual at kmbs.konicaminolta.us
Posted on May 13, 2010
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
How do I change the netwok IP address on the c250
Hi CTF3,
To change the IP address of your Bizhub C250:
Push UTILITY/COUNTER
ADMINISTRATOR SETTINGS
put in the password, should be 12345678 unless someone has changed it.
NETWORK SETTINGS
TCP/IP
I think you NEXT few the next screen and you should see the IP address which is currently assigned to the device.
Hope that helps
Kind regards
M-Press.biz
Feb 21, 2011 | Konica Minolta bizhub C250 All-In-One...
We have a Konica Minolta Bizhub 250 at the office and I want to use it as a scanner...I connected the printer to my laptop using a USB cable but it doesnt send the scanned files to my PC. I'm not really...
First of all, bizhub 250/350 is not a single pc scanner.you cannot use it as a scanner by connecting usb cable with it.its a network scanner.so to use it as a network scanner, you have to do these main steps........
1-assign a free ip address to the machine.
2-ping it from the system to check the connection between machine and computer.
3-now, make a scanner one touch account on the machine.
4-enter computer's ip address in the destination option.
5-create a folder on the desktop of your computer and share it.give it full rights.
6-turn the firewall off.
7-enter the folder name which you have made, in the machine.
8-enter user name and password of your computer in machine.i mean while making scanner one touch account.
9-now place the original on glass and scan it........
Aug 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Have 3 cd's that came with it. Want to print from network PC. Seems like the Printer is not broadcasting IP address. How to find the IP of the printer. Bizhub 350.
if you are using for the first time as a network printer then you should first know how to assign the "IP ADDRESS" to machine/printer. to check the ip address of the printer, simply go to " Administrator" mode, and check ip there.
all the best...........
Jun 13, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250 All-In-One Laser Printer: My bizhub c250 is going through a hub to a router....
Type in the ip address of the copier in your web browser. You should be able to log on to the web image monitor and even print a test page. If so you are 90% of the way there. Now go back to the printer setup screen in windows and click on the "port" tab then on configure port. Make sure the port ip address is the same as the copier and make sure the port number is 9100. Keep in mind that the ip address of the copier needs to match the ip address of your network for the first 3 sets of numbers. So if your network ip is 192.168.50.50 the copier would need to have an ip address of 192.168.50.xx
Good Luck and Thank You for using Fixya
May 17, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
337 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
