Question about LG 42LC2D 42 in. LCD HDTV
I have a 42LH90 television which has an optical audio outlet, where do I get speakers and cable for this
  • LG Master
  • 736 Answers
You can purchase a fiber optic cable from Sears or any store with an electronics department i.e. RadioShack or Walmart or even a Fry's or HH Gregg and etc. I recommend a sound bar that has a digital audio input because it does not sound like you are interested in having seven speakers going all the way around the room
Posted on May 06, 2010
Testimonial: "Thanks very much for your help. I really dont need 7 speakers, I just need a speaker or speakers where the sound can be amplified but my problem is its difficult to get a speaker with optical cable input"
  • LG Master
  • 8,457 Answers
Look in ur user manaul it shuold give a list of products to use with ur Optical Audio outlet.The Optical Audio cable u can buy it at websites like Amazon.com,Ebay.com.The Audio System,to use have the best surrond sound .Tries the Yamaha or the Bose the Audio System unit.
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Try to go digital optical out to a receiver for surround sound (also Samsung) but not sound comes out. Tested it with a Samsung Blu-Ray player digital optical out, and it worked.... is this a problem with...
The digital audio outputs on televisions sometimes only work when the television is on certain inputs. It does not always work with all hdmi connected devices. I can almost guarantee you that if you connected an over the air antenna to this television and scanned for your free local television channels the digital optical out between the tv and the surround sound would work.Likewise if you have Comcast or one of the other cable carriers that has digital cable you could connect the coax cable directly between the television and the cable wall outlet without the cable box and get sound from the tv's digital audio output to the surround sound.
However there might be a digital audio output television setting you have not changed. Refer to the manual for that or call customer service if necessary.
Jun 10, 2011 | Televison & Video
Can i connect pc speakers to the toshiba 55HT1U?
The 55HT1U only has Optical Out (TOSLink) for audio, so you will need an intermediary receiver with optical-in in order to connect up most speaker systems. If you have a higher end set of PC speakers, it may have an optical port on the receiver module or subwoofer. If so, it'll work!
See http://upload.wikimedia.org/wikipedia/commons/4/4d/TOS_LINK_clear_cable.jpg for an example of what an optical cable/connector looks like
Mar 14, 2011 | Televison & Video
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
Mar 01, 2011 | Durabrand 5.1 Surround Sound Computer...
I want to connect external speakers to LG LD400 LCD TV . Please tell me the type of wire used to connect the same to LG LCD
You can use stantard audio cables or a optical audio cable either way you must have a reciever
Dec 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Plug for pc speakers wire
To use the speakers on the TV when you connect to a PC, get a 3.5 mm M/M audio cable (it may be called a patch cable or audio aux cable) and connect it to the PC audio in port to the left of the composite A/V ports (that's the group with 3 RCA jacks yellow (video)/red(R audio)/white (L audio)). The other end goes into the computer's line out (speaker out) port - which is generally colored green. Otherwise your regular computer speakers will play the audio.
If you want the TV's audio to output to external speakers, use the headphone jack (sometimes labels Phones, again a 3.5 mm plug) or a set of speakers/receiver that takes an optical audio connection. The optical audio jack is between the two coax connectors. Please note using the headphone jack will force the internal speakers off.
I hope this helps.
Aug 31, 2010 | Protron PLTV3250 32 in. LCD Television
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
LG 42LC2D 42 in. LCD HDTV Logo
145 people viewed this question
Computer Repairing
Computer Repairing
