Question about Hamilton Beach BrewStation 47214 Coffee Maker
Why does unit fill cup very slowly when the inside filter appears clean.
  • Hamilton Beach Master
  • 43,501 Answers
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Posted on May 06, 2010
  • nonadd May 27, 2012
    I have cleaned my brew station at least once a month. This last month I used straight white vinegar and still coffee comes out very slow. Any other ideas? I like the way the coffee maker worked before but will have to toss it if I can't fix it.
Have a bunn vps series pour over that won't brew
VPS are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on. Brewer will pre-heat the water (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* You can test the VPR by following the Pre-fill instructions I've listed earlier. If the brewer heats up and does not continuously boil (shorted condition) then try a brew. If it works then your okay. Otherwise the unit will need service for a blown high limit or bad heater element.
* Call your coffee vendor anyway. Many coffee vendors will service your brewer of even replace it as long as you buy coffee from them. Ask around.
Aloha, ukeboy57
May 27, 2017 | Bunn Coffee Makers & Espresso Machines
Fill with water on indicator
Remove the water reservoir clean the inside and dry. Pull the filter screen and rinse. Put 2 cups of water in the container and shake well for a few minutes. Empty and Dry again. Reset as per the manual, fill to the line and with the filer removed, do a dry run without the kcup in place.
Feb 01, 2014 | Keurig B70 Coffee Maker
My 12 Cup grind and brew coffee maker needs a good cleaning. How do I do it?
To clean the inside of the coffee maker, fill the reservoir with water as you would to prepare coffee, except add 2 tablespoons of vinegar to the reservoir. Place a clean filter in the basket and run the solution through. When it is complete turn off the unit and let it cool for 2 minutes and then pour the hot solution back into the reservoir for a second run, you can reuse the filter that you placed in it the first time. After it is finished this second time, turn off the unit for 2 minutes and pour the used solution down they kitchen sink. Allow the carafe to cool for a couple of minutes and fill with cold water and run it through as you did the solution, but put a clean filter in this time. Repeat this one more time to remove the vinegar solution and discard the used filters. Once the carafe is cooled fill it about 1/3 full of water, add several ice cubes and 1 tablespoon of baking soda swirl this around in the carafe for a minute or so. Rinse the carafe and run it and the basket through a cycle in the dishwasher or wash by hand with warm soapy water. Rinse thoroughly and you're done. Good luck.
Aug 28, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
On my old Hamilton Beach Brew Station the machine made coffee just fine, it would just very slowly dispense the coffee into my coffee cup. The interior of the holding reservoir (this is where the already made coffee sits and is kept warm) was heavily stained by coffee (it was black) and the small dome shaped screen filter (this filter keeps coffee grounds from getting in your coffee cup) appeared black and clogged. I used a product called Krud Kutter available at Walmart. I poured enough of it in the holding reservoir to cover the filter and let it sit for about three hours. It now looks like new. DO NOT run this cleaner through the coffee making cycle. Dump the cleaner out and rinse the reservoir out several times with fresh water. The final step is to run a coffee cycle using just fresh water at maximum water capacity and just let it sit for a while as you would a brewed pot of coffee leaving the pot ON to keep it hot. This will allow any Krud Kutter residue to be removed.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
It is not cleaning. How can I clean filter?
First of all i had !!! the same unit , we had so many problems with it I gave up and purshcast a GE cheep one. never had a problem since, but getting back to your problem , the only filter is the bottom of the unit looking inside , I dont care what they say you need to prerince everything , and use a good soap , I find useing less soap is better then filling the door cup to the top, We replaced the door switch twice and the main panel inside once and also had problems with the touch panel it is a very poor system for what you paid for this unit , good luck with it Guy
Jul 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have my Mom's 193909WB coffeemaker, It runs like a top! How do I clean it?
Here are the cleaning instructions directly from West Bend's instruction manual. Good luck!
Cleaning Instructions
1. Unplug coffeemaker and allow to cool before cleaning.
2. Clean basket, stem and cover in hot soapy water with a dishcloth, rinse and dry. Coffee stains on underside of cover or stem may be removed by scouring with a damp cloth and a non-abrasive cleanser.
3. Clean inside of coffeemaker by filling with hot water until about one-third full. Add small amount of liquid dishwasher detergent and wash with a dishcloth or sponge. Then clean the heating unit well (where stem fits) with a scouring pad, to remove coffee residue. Twist pad inside heating unit well to clean thoroughly. IMPORTANT: If heating unit well is not kept clean, coffeemaker will not perform properly.
4. After cleaning inside of coffeemaker, drain and rinse inside. Clean faucet by letting clear water run through it into sink, while moving faucet handle up and down. Drain water from inside of coffeemaker and dry.
5. Clean outside of coffeemaker with a damp cloth and dry with a soft cloth. Do not use abrasive metal scouring pads or cleansers on outside of coffeemaker as scratching will occur.
DO NOT WASH COFFEEMAKER PARTS IN AN AUTOMATIC DISHWASHER.
Special Cleaning Instructions
To Remove Mineral Deposits: If coffeemaker is used daily, a special cleaning every 2 weeks OR every week if used for heating water, is necessary. Fill coffeemaker with 1 quart each of water and white distilled vinegar. (If a white mineral buildup has formed on inside of coffeemaker, use an additional 2 cups of vinegar.) Place stem and empty coffee basket in place, secure cover onto coffeemaker and plug in. Allow coffeemaker to complete perking cycle, then let stand for 10 to 15 minutes. Unplug and drain coffeemaker. Allow to cool and follow general cleaning instructions.
To Remove Discoloration: Inside of the coffeemaker can discolor when used for heating water, which is normal. To remove/lighten discoloration, fill coffeemaker with water to the level of discoloration (at least to the 12 cup level, but not past maximum cup level). Place stem and empty basket in place. For every 12 cups of water added to coffeemaker, add 2 teaspoons cream of tartar to basket. Secure cover onto coffeemaker, plug cord into coffemaker and then into outlet and allow coffeemaker to complete perk cycle. Let stand for 15 to 20 minutes or until discoloration is lightened. Unplug cord and drain coffeemaker. Allow to cool and follow general cleaning instructions.
Do not use baking soda to clean coffeemaker, as it will discolor inside metal.
After frequent use, coffee residue may collect inside faucet. To clean, unscrew top half of faucet. Move a small brush up and down through faucet. Insert brush through opening inside coffeemaker to clean faucet connection. Rinse and replace top half of faucet.
Jan 11, 2011 | West Bend (58036) 36-Cup Coffee Maker
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
DCC-1200 coffeemaker cleaning button flashes constantly after it starts,slowly makes coffee and is strong and lots of steam. I have cleaned twice with vinegar solution. What should I do. The coffee maker...
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Aug 21, 2009 | Cuisinart DCC-1200 Coffee Maker
My miele espresso maker dispenses too much water in my espresso. how do I fix this?
If you fill two esspresso cups at the same time it should be the correct size. But if it is weak, see below...
For one cup, press the small coffee button to start. Press the button again when the desired amount of espresso is in the cup to stop the flow. if it is too watery but the correct amount see below.
If the espresso is too weak push the coffee grinds slide switch inside one notch finer and make another 3 cups. If the flavor does not get strong in 3 cups then there is an anomaly happening. The brew unit upper filter has gunk clogged behind it to a point where the pressure (230psi) of hot water trying to get through the gunk pierces a small channel through only a portion of the filter screen. All the water is running through only 4 or 5 holes in the filter screen. This eddy allows hot water to pass most of the grinds without extracting flavor. It's the same as if you clogged a sink strainer then pushed the blockage off part of the strainer. The water goes around the coffee not through it. The path of least resistance.
Remove the upside down stainless steel filter on the brew unit- Remove the screw using the allen key that came with the machine. It goes through the little finger nut on the top of the brew unit. Turn it counter-clockwise (lefty loosy) and the filter will come off from underside. The area behind the filter screen has to be cleaned of any coffee residues. Also check thew creme valve. It is under spring tension accessible from the top of the brew unit by removing two screws holding the long pipe on top. be careful not to let the spring shoot out and loose the creme valve. It looks like a plastic rivet on the other end of the spring. Clean out the entire channel by rinsing. Use a pipe cleaner for dried on grinds.
Note: the finer you set the grinds the quicker it clogs the filters. Increase the use of cleaning tablets when you grind finer coffee. A clogged brew unit is almost impossible to clean even for the most handy of people and the last I checked a new brew unit is well over 200 bucks! Good luck!
Jul 30, 2009 | Miele CVA615 Espresso Machine
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Hamilton Beach BrewStation 47214 Coffee Maker Logo
1,147 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
