Question about Dishwashers
My bosch SHX33A05UC dishwasher wont drain drain
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Posted on May 06, 2010
Bosch dishwasher does not drain water and does not run
Bosch,. like many others have a "safe: cycle where the machine will always do a short pump out before it starts any cycle. If it fails to do a pump out even if there is no water in the machine, the machine will go into safety mode and will not allow a program to start. You will have to pull the machine out and check if the drain hose is blocked or kinked, and that the drain pump is not blocked or jammed. Toothpicks, bits of food and broken glass fragments are good for blocking / jamming dishwasher pumps.
Mar 09, 2015 | Bosch Integra 300 Series SHX33A05UC
Shx33a05uc won't start washing
bosch smu -4052 will not fill with water
Aug 08, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
Aug 13, 2011 | Dishwashers
My Bosch SHX33A05UC model that I bought 8 years ago won't clean my dishes anymore. Replaced spray arm. still won't clean
Hi newbould4,
Please follow my below Tip on how to get the best results from your Dishwasher:
DISHWASHER NOT CLEANING WELL ANYMORE...
Kind Regards d")
JEDEMEYER1
* If this solution helped you, please rate it
Jul 31, 2011 | Dishwashers
Bosch shx33a05uc/14 dishes are milky with white chalky residue. Have cleaned the inside, and checked to make sure the water can exit the spray holes in the circulating parts (top and bottom). Checked...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
May 11, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Feb 25, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Black spots on plastic items
I have the same problem on my Bosch dishwasher Model # SHX33A05UC. It is about 6 years old. I have replaced three gaskets and it did not solve the problem. I am a 25 year mechanical engineer. I do not recommend anyone changing these gaskets on their own except for the long dishwasher door gasket (which goes along the top, left and right door edges) which is quite easy to replace. The other two gaskets, which were quite difficult to replace, were the gasket at the bottom of the dishwasher door and the sump pump gasket. I am still having the tar like black tiny dots depositing on my plastic tupper wear on the second shelf. I will likely not buy a Bosch dishwasher ever again. I will make my decision after hearing what Bosch tech support has to say about what I need to replace next. Could it be the rubber drain check valve not operating correctly? I need to find out. I have spent so much time trying to solve this black tar dot problem!!!
Feb 11, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
555 people viewed this question
Top Dishwashers Experts
Owen Barnes
