Question about Insignia LCDTV26 26 in. Television
Do I need a special box for my lcd tv. When trying to connect I get a message that it is looking for a signal.
  • Insignia Master
  • 8,457 Answers
What box are u taking about?The DTV free air signal converter box?No,ur tv is a LCD tv right?Just have a good antena like a roof or a digital antena.Or u talking the paying subcribing Cables companies boxes,Satalites Dish companies boxes,or the Telecom companies like Verizon,AT&T boxes.
Posted on May 06, 2010
  • Chi Chu May 06, 2010
    If u having paying subcribing services like cable boxes,satalites dishes boxes,and Telecom companies boxes like Verizon or AT&T boxes.Call their customer service they'll help u.
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
ERROR MESSAGE NO SIGNAL INPUT
What is your TV signal source? Press the Input button on the remote and try another input. (Make sure a DVD player or set-top box is on.) If you are on the TV input, try a different channel. Next make sure that your cables are securely connected to the TV and devices. Replace with new cables to test them. If you use an OTA antenna with a splitter, try a direct connection. (Similarly, if you have an amplifier on the signal, try a connection without the amplifier.)
For OTA or direct cable connections, try accessing the Channel Setup menu and rescanning for channels.
I hope this helps.
(I get some weak channels that give No Signal messages when the transmitter has a problem or the weather is bad. I've also had a signal splitter/amplifier fail and block specific channels by becoming a filter. The direct connection identified the amplifier problem.)
Mar 06, 2013 | Sony KDL-40VE5 40" HDTV LCD TV
Phillips 47 inch flat screen tv is 4 years old tv comes on but a box says no signal comes up what do I do
Check that you have the tv set to the current input and the correct channel (esp you have a set top box feeding the TV signal). Make sure that device is on and working. Check the cables for damage.
If you are using OTA, make sure your antenna is rotated in the correct direction. If you use an amplifier or splitter, try the signal strength without the accessory. Replace if the direct connection helps.
If the TV is connected to a computer, make sure that the port is active and sending a signal.
If none of these help, you may need to replace the video board or tuner (or both) depending on your source. (Some parts are available at partstore.com and shopjimmy.com (which specializes in minimally used parts from electronics damaged in shipping.)
I hope this helps.
Feb 02, 2011 | Philips 47PFL7403D 47 in. LCD TV
How can I watch a DVD on my TV from my Inspiron
if u have a TV out signal port on ur laptop, u will need a DIN adaptor to connect from laptop to ur TV
else u need a convertor box that will convert ur connect to ur VGA out port on ur laptop and will send the signal to TV via the box to the audio/video in slot in the TV...u will also need some special cables...thsi will come along with the convertor box....look in google or ebay
Feb 04, 2010 | Dell Inspiron 6400 Notebook
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Insignia LCDTV26 26 in. Television Logo
71 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
