Question about Altec Lansing SoundBar FX3020 Computer Speakers
Altec lansing fx 3020 soundbar - fried power supply
I inadvertently plugged a 12V dc supply into my soundbar, instead of the supplied 5V. i sensed something was wrong immediately after i turned the unit on because there was a soft crackling noise then smoke came out of the unit. i unplugged it immediately but the damage was done. after pluggin it in to the correct power supply, it wouldn't turn on anymore. i have some skill in electronic repair, but i'd prefer knowing what i'd need to replace than have to figure it out myself... please help. thanks.
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Posted on Feb 26, 2008
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Posted on Jul 01, 2009
How can I splice Altec Lansing amplified speaker system 221 to ac power supply cord instead of the computer cord
Not a good idea. The receptacle that the computer cord plugs into has EMI filters in it. Bypassing it would cause an AC hum that you'd never be able to get rid of.
Sep 16, 2016 | Altec Lansing Audio Players & Recorders
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
I'm looking for power supply A/C adapter altec lansing acs 340 for 13V 4A
Hello My Friend,
Good day!
We knew your products is AC/DC adpater, we are a manufactory of AC/DC adapter, power supply. we have 3-120W wall type (UK, USA, EU, AU AC plug) and Desk type adapter, with UL, GS, FCC, CE, PSE, ROHS and CEC compliant, with high quality and nice price anytime.
Welcome to inquire anytime.
Sincerely we have a kind cooperation with you.
Kind Regards, Susan E-Stars Int'l Tech. Co., Limited
www.estarspower.com
T:86-755-26784986
F:86-755-26792059
Sep 20, 2010 | Altec Lansing Multimedia Computer Speakers
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
Wrong Power Supply
If it doesn't work with batteries or the supplied power supply than your speakers are fried. Sorry for the bad news.
Mar 03, 2009 | Altec Lansing inMotion iM310 Portable...
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
http://cgi.ebay.com/AULT-041-0001-001-18VDC-1111MA-AC-ADAPTER_W0QQitemZ6741610952QQihZ002QQcategoryZ101265QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Subwoofer making load humming noise
The reason for the hum in the Altec Lansing VS4121 speaker system is the stray field of the power supply transformer. This stray field is strong enough to affect the amplifier. All other reasons given by numerous reports on the web do not apply. If you are handy and have got the time you may mitigate the problem by physically moving the amp away from the power supply or turning it 90 degrees. I managed to lift up the amp in my subwoofer by about 50 mm, which was difficult to achieve and did not cure the problem perfectly. I don't see any other way to solve this problem except you feed DC in from the outside and do not use the internal power supply. That would be really odd indeed
Gerhard Weber.
Jan 29, 2009 | Altec Lansing VS4121 Speaker
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
Feb 20, 2008 | Altec Lansing Multimedia Computer Speakers
Altec Lansing SoundBar FX3020 Computer Speakers Logo
160 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
