Question about ASK Proxima Proxima DP2000S Data Video Projector ( DP-2000S, DP 2000S ) Multimedia Projector
Need Drivers I purchased an InFocus LitePro 570 LS Projector 2nd hand. I have the VGA plugged into my laptop, but still don't get an image - just the light projected. Do I need drivers for my PC to get this older model to work? Thanks, Jess
    Problem Solver:
  • 6 Answers
Specifications Display Type Active Matrix LCD Brightness Lumens 300 Contrast Ratio 100:1 Native Resolution Compatible Resolutions VGA (640 x 480), SVGA (800 x 600), Computer Inputs 26pin (Y cable for HD15), HD15, 2 x RCA (L,R stereo audio), RS-232, Video Inputs 2 x Composite video (RCA), 2 x S-Video (4-pin mini din), 2 x Video Audio RCA (L,R stereo), Other Inputs Microphone XLR-type Outputs Stereo audio (RCA L,R), Video Compatibility NTSC, PAL, SECAM, HDTV Support none Audio 2 x 5-watt stereo Lamp Type 400W Halogen Part Number SP-LAMP-LP Life 40 hours
Make sure that your PC/Laptop source resolution is set to VGA (640x480) or SVGA (800x600)
Posted on Nov 19, 2008
  • 563 Answers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Posted on Mar 27, 2008
I want to project to a wall or screen from my laptop and or my flash drive/but how?
connect VGA cable to ur projector and the other end to ur laptops vga
generally newer laptops dont have a vga
thy only have a hdmi out
so you may need to purchase a hdmi to vga convertor to be able to display on the projector screen
also depends on which model of Infocus projector u have!
Jun 05, 2015 | InFocus Office Equipment & Supplies
Infocus litepro 550
1, the VGA cable or your laptop is something wrong
2,the interface boar (on the mother board) of the projector is broken
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 16, 2014 | Office Equipment & Supplies
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
I own an InFocus Litepro 570LS. The projector light bulb blinks on and off.....I do not know how many hours are on the buld and the spare buld is burned out....what is a possible fix.
Given that the bulb actually lights up and then goes out you need to check the contacts at the base of the socket to ensure proper contact is consistently made at the base of the bulb. Be sure to unplug the projector prior to inspecting and adjusting.
May 17, 2011 | InFocus LitePro 570 LCD Projector....
Have an infocus litepro 580, lamp and speakers works fine. Projector will only show the "infocus systems" opening display without changing to my video source. All cables are correctly in,...
Go into the settings menu of the projector and turn off the auto source function, then select the input that you are using.
if using a laptop you may have to simultaneously press your FN and relevant 'F' key to send the signal out to the projector. The 'F' key usually has an image of two side by side monitors or it says LCD/CRT. Wait a few seconds each time for the signal to be sent to the projector. Sometimes you may have to repeat this action 3 times to get the image on both your laptop and your projector.
good luck
Mar 08, 2011 | Office Equipment & Supplies
Do they make brighter bulbs for the LitePro 580 projector
Nope. You can NOT increase brightness of a projector by installing a brighter lamp. Sorry. The only option is replacing the projector with a brighter model.
Oct 20, 2010 | InFocus Litepro 580 Replacement Projector...
Need image to show on both the HP laptop and the InFocus IN15
make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
Jun 04, 2009 | InFocus LP70+ Multimedia Projector
Discoloration
Please contact Swati@justlamps.com.sg for all your projector lamps needs. We provide orignal projector lamps with casing. We stock all Brands & Models avaialble in the market today.
Jan 21, 2008 | InFocus Litepro 580 Replacement Projector...
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
http://www.infocus.com/Support/Products/Projectors/IN24.aspx
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
ASK Proxima Proxima DP2000S Data Video Projector ( DP-2000S, DP 2000S ) Multimedia Projector Logo
171 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
