Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
I'm trying to change the interior bulb on my JVM1490SH01...
GE Microwave. Any help would be appreciated. I see it's a 20W, 120v bulb.
  • GE Master
  • 9,086 Answers
You didn't mention your brand or model, and your subject line got cut off, so I'm not sure which part of the process is giving you trouble. So I'll take a stab at giving you the info you need:
You can download GE owner's manuals and installation instructions here.
You should be able to download your LG / Goldstar manual here. If not, you can contact them via that page to order one.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 06, 2010
The interior bulb of my ge spacemaker oven jvm1490sh01 has blown out. How do I go about replacing it? Thanks
HI,
I looked up your model and found that if you remove the grill above the door, you can ***** the bulb area. With the grill removed, in the middle left side, you will see either a black or metal looking cover, if I remember correctly you slide the cover back toward the wall and lift up. There is where your bulb should be.
If you would like unplug the micro way before you enter this area for safety only. I normally don't but I know what I am looking for.
Good luck, be safe
Jul 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
I need to find an incancent 40w 120v bulb for microwave
This is a common item. Take the bulb to a home depot and they will match it for you or direct you to a local source.
please mark my answer as a fixya!
Mar 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag microwave light bulb MMV5207BA/BC
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
Aug 20, 2008 | Microwave Ovens
Interior Light GE Advantium replacement
Yes, that's right. Very common, standard 10W halogen available about anywhere. GE's # is WB36X10163 or WB36X10177.
Jul 18, 2008 | GE Advantium 120 Convection/Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Nov 26, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
512 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
