Question about Microsoft Xbox 360 Elite Console
It is flashing 3 red lights and a green light on the 2nd power in the back I tried going on your website on it but it never worked.
    Scholar:
  • 91 Answers
Here are the two things i have used to fix this issue although I cannot guarantee it %100 it does have a decent chance of working if done right.
http://www.instructables.com/id/Fix-the-Red-Ring-of-Deathwithout-towels/ http://www.consoleshop.com/home.php?cat=264
Posted on May 06, 2010
My ps3 will not power up
here is step by step trouble shooting
1) attempt to turn on the ps3
+you will see one of 4 things a green yellow red light
+flashing red light
+green light
+no lights
2) if you see a green yellow red light call sony your system will need service
3) if you see a red flashing light also call sony needs service
4) if the light is green turn off the system and one the light is back to red press and hold the power button for a series of 2 beeps (do not forget the one when you first push the button down) then let go (it might be a video issue)
5) if you still see no video and a green light check the cable you are using and try again on a different tv
6) if you see no power light call sony it needs service
these are genuine trouble shooting steps from sony technical support if you do have to call them be prepared to follow the same steps that lead up to service. thank you
Oct 30, 2011 | Sony Playstation 3 (PS3) Console
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Ps3 problem
May 03, 2009 | Sony Playstation 3 (PS3) Console
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
My ps3 doesnt work
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Elite Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
