Problem with black screen
Toshiba Satellite A105-S2141
It was very hot after it was shutdown? over night, the next day, it would not come on until I took out the battery and put it back in. Since then it worked for a couple of days but will not go into hybernate mode. It now only has a blank screen when you turn it on.
    Sergeant:
    Champion:
  • 329 Answers
Have you try to check your battery? try to put some colling fan to your laptop to avoid hybernation of your notebook..
Posted on Mar 26, 2008
SOURCE:
Toshiba sateille A105 s2141 black screen at start up
check the laptop using an external monitor and if there is no display then the mother board is faulty and will need the help from a service center.
If there is display then it is confirmed that the LCD panel is faulty. It can be due to faulty LCD, linking cord to the panel or an interface failure of the display section.
All of the above will require that you must have some test equipments to confirm.
Aug 11, 2011 | Toshiba Satellite A105-S2031 Notebook
Broken screen, need repair manual to fix same.
You can get the manual at any of these sites:
www.eserviceinfo.com/index.php?...Satellite...A105...
repair4laptop.org/disassembly_toshiba.html
www.irisvista.com/tech/
Jan 01, 2010 | Toshiba Satellite A105 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Mar 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Lost hdd password and systems recovery CD
click on the following link
http://www.pwcrack.com/harddisk.shtml
This gives you detail description of HDD pasword and from where to get it recovered
Oct 13, 2008 | Toshiba Computers & Internet
Display shutdown
The next time this happens, try to manually operate the lid switch a couple of times. These switches can go bad and allow the unit to go into hibernation mode.
Ron-
Feb 23, 2008 | Toshiba Satellite A105-S4074 Notebook
Toshiba Satellite A105-S2141 Lockup
Have you checked the heat of CPU? It might be cause of CPU overheating.
Nov 20, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
Computers & Internet Logo
70 people viewed this question
Ekse
Alun Cox
