Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
No hot water
Water company turn off water to fix water problem went it cam back on no hot water
  • Rheem Master
  • 43,501 Answers
The water level probably dropped enough in the water heater to et the top element out of the water and it burnt out that element...
Check out this tip that I wrote about this....
Electric Water Heater not Working
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
There are also a few otthers links to tips at the bottom of this tip that will help with replacement and adjustment...
heatman101
Posted on May 06, 2010
Not getting any hot water what do i do?
I suggest getting in touch with your boiler company. They'll come out and check your thermostat, check your pipe's aren't freezing and that your boiler is igniting at least. P.s. I had this problem recently down to user error, been cold recently so had the heating on often then wondered why my water was chilly :S
Dec 05, 2015 | Water Water Heaters
Electric went off the control panel is dark and no hot water
It sounds like you have electronic ignition for your burner and not a gas pilot. If it's an electric water heater than the problem is probably similar. There is a small transformer that interfaces with the knob that controls the water temperature. Sometimes they need a reset. Turn off the breaker , wait a few seconds, and than turn back on. If it's a gas pilot type it still has a transformer but the breaker trick may not be the solution...though it doesn't hurt to try. If this is the case you may need to relight the pilot. Follow the instructions located normally just above the water temperature control knob
Aug 22, 2014 | Rinnai Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
Hi, we are renting and have no hot water. We have a water wizard on the outside of the house. Should we have connected with a gas company? Or does it run on something else?
If you're renting then you should call your landlord and have them fix it. thats the beauty of renting, this is not your responsivility
Feb 04, 2012 | Water Heaters
The gas company has come out twice becuase the pilot went out. He found a leak and fixed it and i had a hot water shower once before it went out again. He came out a second time and did the repair again...
A number of things can affect the pilot.
Unknown if this is new heater or heater that stopped working.
Unknown what type of gas valve is on water heater.
Unknown what the gas company man observed, and why he said call manufacturer, and what he repaired. Was the gas control valve leaking?
Unknown what type of general maintenance and testing has been done.
Option 1) The gas company said call the manufacturer.
Information shows on label on side of tank.
http://waterheatertimer.org/Water-heater-manufacturers.html
Option 2) Open following links and start reading. And then try to fix yourself.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Option 3) Call gas company guy and ask him exactly what he observed, write that down, and then add a comment with very specific information for possible help.
Option 4) Call local plumber and tell him the specific information that gas company man said, and see what solution he can offer.
Aug 18, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
I have a humming and knocking that is happening in my pipes. It seems to be related to my hot water heater. I have unplugged the heater and that helps most of it, but there are still times during the day...
Knocking water pipes are caused by air trapped in the pipe. If the pipe only went uphill and horizontal, the air releases out of the faucet and doesn't cause a problem. But if the pipe takes a turn back down, there is an opportunity for the air to remain trapped. Try this ---. Turn on all of your hot water faucets full blast at the same time. Start with the highest faucet farthest from the hot water tank and work your way back to the one closest to the hot water tank. Count to ten, then close them in reverse order. If that doesn't clear the air, then look for a place where the pipe travels horizontally then back down. If such a place is accessible, and if the pipe is copper, buy a self-piercing tap of the type that are used to supply water to an ice maker. Install it and let some water out and hopefully some air out. If you also attach a section of clear hose you and you open the valve very slowly, you will be able to see the air bubbles in the hose. I use just such a setup on my hot-water heating system and it works like a champ. Good luck!
Nov 26, 2010 | Water Heaters
If main water supply line is shut off and thermostat is turned up on my gas water heater could relief valve open ?my girlfriend was taking a bath and told me the water pressure was weakening and water...
pressure would go down any time the water is cut off. Temp went down no make up water relief went off cause you turned it up. put it back and put the main back on.
May 09, 2010 | Water Heaters
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
54 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
