Question about Pioneer AVIC-D3 Car DVD Player
D3 doesnt turn on except when bypassed
My car had the battery unplugged for a while. when i reconnected it, it went through the usual security password and then started to work. when i turned the key off, then back on it doesnt turn on and i can;t figure out how to turn it on. If i hit the bypass button, it asks for the password, then turns on but only until i turn the key off. Then it doesnt work again. It gets power, just doesnt operate. Its as if i turned the unit off.
    New Friend:
  • 113 Answers
Check the yellow (12 volt constant line) wire and make sure it has power to it even when the ignition switch is not on
Posted on Mar 28, 2008
SOURCE:
Have a 2002 tahoe with a gas leak and a problem with the flashers took for repair fixed but went into theft mode and wont start how can it be started
you can try this ,Try and do 30 Minute Learn Procedure
Turn ON the ignition, with the engine OFF.
Attempt to start the engine, and then release the key to ON, vehicle will not start.
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
Turn OFF ignition, and wait 5 seconds.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready to relearn the Passlock? Sensor Data Code and/or Passwords on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learn the Passlock? Sensor Data Code and/or Password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock? Sensor Data Code and/or password.
With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
May 17, 2017 | Cars & Trucks
Why no power after battery charged?
If the battery was disconnected to recharge, it may not have been reconnected securely.
The battery could have a dead cell.
Sep 05, 2015 | Cars & Trucks
My battery died, so I needed to jump start my battery. When my car started again, my screen was asking for a four digit password. I think I entered the wrong number in one too many times, so now the...
  • You can try to disconnect the battery again for 5 minutes and then reconnecting it and see if that brings your screen back up. If it does not then your radio has gone into PUK mode. PUK mode is what happens when the wrong code is entered to many times. It's a lock that can only be overridden by contacting the manufacturer of your radio. This is a security feature. Good luck.
Regards, Tony
May 06, 2011 | Car Audio & Video
I have a 2004 Audi A4 and I went to start it today and t was dead. I jumped it and the alarm went off, the EBS light is illuminated and both turn signals (like hard lights but faster) are continuously...
Sounds like your security system thinks your stealing it. Try locking and unlocking manually. Jump starting can sometimes damage electronics not usually a good idea. It is better to disconnect the battery and charge it then reconnect it. You may have blown the EBS fuse which may be mounted ont the ebs computer.
Dec 11, 2010 | 1999 Audi A4
I have a GE home security system. Last week there was a power surge due to a blown transformer in the neighborhood. A few hours afterward the systems siren sounded & would not turn off. So we...
It might not hurt to try the "Microsoft Solution" and reboot the system. First disconnect the AC power then disconnect the battery. Wait 1 minute then reconnect the battery and reconnect the AC power.See ifyou can arm and disarm the system. Then reconnect the siren and try again to arm and disarm the panel. If the keypads beep it can usually give you an error code that will help you pinpoint the problem.
Aug 30, 2010 | GE Security Simon 3 Wireless Home Security...
Battery went dead replaced battery now key fob does not work
First, look around the battery area and make sure you didn't forget to connect a wire (usually a red or black/ground); sometimes they manage to fall down near the frame or block and are not hard to miss when reconnecting wires; then, if all wires are connected, contact a representative at a local auto parts dealer and ask if it would be safe to unplug the computer and reconnect it. This should be okay, as long as the engine is off. Then, start the van and see if the fob works (if inside of van is accessible).
Please let me know if you need further assistance,
Guru, Premium Expert @ Fixya.com
Jul 12, 2010 | Cars & Trucks
Cherrokee jeep immobilised, after battery went flat. jumped battery, disconnected battery and reconnected to try to re set alarm, phobb works,on alarm but when key turns no turn over,?
If by turning over you mean that the engine isn't turning when you turn the key, then you have a failure in the starting system. (check battery, connections, relay and starter) If the engine turns but dosen't start, try locking and unlocking the drivers door to re-set the security system.
Feb 23, 2010 | 1997 Jeep Grand Cherokee
1996 Dodge Avenger Security System went crazy now car won't start
try to put the key in the ingnition and turn it to the on possition and walk away for about 15 min come back turn it to off and see iff it starts
Dec 30, 2009 | 1996 Dodge Avenger
Security?
you are going to have to call the car dealer for codes. its mostly all intergrated.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 18, 2008 | 1994 Dodge Viper
Pioneer AVIC-D3 Car DVD Player Logo
278 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
