Question about Kenmore Dishwashers
The dishes do not come out clean in our 2 year old kenmore elite - recently there seems to be an oily film on them especially the glasses. Is there a treatment available?
  • Kenmore Master
  • 12,061 Answers
Http://www.partselect.com/dishwasher+dishes-not-clean+repair.htm
There can be a few reasons why this is happening, so i have given you a link, above so you can see what to do to troubleshoot and diagnose the problem, and what to do to fix it.
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
Please have a look, and download, at ALL the links, and use the service manual to troubleshoot and repair your unit
Also, in this model, always use the Normal/hi temp or Pots/Pans.
Give it a clean. .Remove food and broken items from drain. Take the bottom dish rack out of the dishwasher so you can reach the drain at the bottom. Gently (you may want to wear rubber gloves) run your hand all the way around the drain. You may find bits of broken glass or porcelain dishes (if anything has broken in your dishwasher). You may also find broken bones and large chunks of food if someone was careless about loading your dishwasher.
Clean out door seals. Food and other dirt accumulate around the seal. Use a gentle cleanser to clean all the way around the door seal, especially at the bottom where food is most likely to fall when you are loading the dishwasher.
Use an acid-based cleanser and run a wash cycle with no dishes in the dishwasher. Some of the most common options are Oxyclean, white vinegar, bleach, lemon Kool-Aid drink mix, concentrated lemon juice or Coca-Cola. The best idea may be to use a small amount of bleach to kill germs, then lemon drink mix or lemon juice for a fresh smell.
Skip the dry cycle. After running the acidic cleaner through your dishwasher, do not use the dry cycle or you may re-harden the gunk you have just dissolved. Use your dishwasher a few times before using the dry cycle again, in fact, allow the dishes to air dry whenever necessary
Posted on May 06, 2010
The dishwasher doesn't seem to be cleaning very well any more. The glasses are always dirty and the dishes just don't seem to be clean like they used to be. Does the dishwasher need some maintenance? ...
Check the following:
- The Salt Container - Found at the bottom of the Dishwasher. (If required, replenish salt)
- The spray arms (They usually get clogged at the small holes where the water should spray out of)
- Us less heat (High heat can leave white visible stains on glass)
Hope this helps :-) - J.Q
Feb 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The dishwasher is not cleaning well. There is a film left on the dishes and especially the glasses.
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Nov 30, 2010 | Kenmore 24 in. 16039 Built-in Dishwasher
My Kenmore Elite dishwasher leaves soapy residue on the dishes leaving them looking dirty., especially in the area of the soap dispencer. What can I do to resolve this problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Aug 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a kenmore elite ultra wash he (model 665.1315) dishwasher - one year old. No problems until recently. It just started leaving a substantial film on the dishes, cutlery and racks in the past 10...
there is calcium in water and it builds up around the pump and the flow you typically have to take it all apart to clean it or there is crud in your drain inside the dishwasher, basically you are swishing around the dirty old water and food particles, Ralph this is from not rinsing dishes first and using special dishwasher soaps to prevent the build up thus clogging pump and exit lines. pull the pump apart if you dont find clogged filters.
Nov 24, 2017 | Kenmore Dishwashers
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
