Question about Mitsubishi WD-73733 73" HDTV
I have a Mitsubishi WD73733 and it has developed white spots scattered across the screen and they resemble points of light in a planetarium.
  • 2,335 Answers
I can help you understand what is happening in your Mitsubishi WD73733.
This is a very common problem for DLP TV's.
What is happening is that the mirrors on the DLP chip are sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.
That said, there is a separate controller board for the DLP called the DMD. The DMD board can be purchased and installed separately from the light engine and typically sells for less than $200, if it can be sourced.
A failing DMD will show the same white dots on the screen as a failing light engine. Your service technician will be able to tell the difference once he has had a look at the TV's guts.
I hope you are under warranty or have an extended service plan for your set. If not, I hope the $200 part is the problem, not the $800+ part.
I hope that helps.
Posted on May 06, 2010
Mitsubishi hd 1080
It sounds that the panel need replacement.
Jun 22, 2013 | Televison & Video
52 mitsubishi has small white dots of light that dont go away on most of the screen
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #'s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT...if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she will also pay half of the $200 labor fee, so you go from $400 to repair to only $100. Once that chip is replaced, the unit works great again!!
Jul 19, 2012 | Mitsubishi WD-57733 57" HDTV
White dots on screen
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Jun 17, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have White and black dots on the screen of my Mitsubishi wd-73833 tv.
Jun 17, 2011 | Mitsubishi Televison & Video
White spots all over picture screen.
optical engine failure. that technology is called DLP digital light processing and it uses a device called a DMD digital micomirror device that has millions of mirrors onthe face and they independtly move and sometimes they can get stuck or not move and cause spots black or white across the entire picture. i suggest calling customer support for possible repair accomodation the cost of the optical engine is around $1100.00+tax plus labor for professional installation part number - 938P075040 phone # for mitsubishi 1(800)332-2119 good luck
Jan 07, 2011 | Mitsubishi WD-57833 57" HDTV
My tv model wd-57733 has hundreds of black and white spots on screen.what is the cause and how do i fix it?
Dec 28, 2010 | Televison & Video
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Mitsubishi WD-73733 73" HDTV Logo
949 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
