Question about Microsoft Windows XP Home Edition Service Pack 3 Full Version OEM for PC
Caps lock key not working - held down the key for
Caps lock key not working - held down the shift key for too long, now caps lock not working - either goes upper case or lower case continually ? .
  • Microsoft Master
  • 4,737 Answers
Press shift key for at least five times and then release when you hear a peep sound, On the Keyboard tab, uncheck everything and click Ok, if this doesn't solve, then again press five times and uncheck everything and click Ok. I also like to know if you were typing on some program like Ms-Word when the problem occurred. is the caps lock led on? Please let me know so that I can help you better.
Posted on May 23, 2010
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
My shift key is not working properly in my Keyboarding online class. It gives me an error everytime I try to key in a capital letter. i have changed keyboards and it still does the same thing.
When you say it gives you an error, do you mean an actual error message, or the lower-case letter?
I have no idea what your experience is, so I'm asking if you know the difference between the Caps Lock key and the Shift key? The Shift key has to be held down while pressing the other key, eg h key to get H.
Pressing the Caps Lock key locks into upper-case, SO YOU GET A LINE LIKE THIS until you press it again.
Apr 08, 2010 | Computers & Internet
My @ button is mixed up with 2 please help me solve this
Hold the SHIFT key down, and press the '2' key, to get the '@'.
Or, make sure that the CAPS LOCK is _not_ engaged.
Or, hold down the 'ALT GRA' key, and press the '2' key, then release that "held" key.
Apr 07, 2010 | Computers & Internet
The Caps Lock/Shift key jammed on my Olivetti Lettera 32
Sounds like the shift key lock spring is broken or missing. Look ont he key and hook it up or find a tiny spring to install.
Dec 13, 2009 | Office Equipment & Supplies
Working on microsoft word _ i@m a writer _ and held down shift for too long _ sticky and filter keys came on _ so cancelled same but now all is gone mad _ all text is selected _ caps locked etc
the solution is you again press shift key 5 times and window will come and go to setting on keyboard tab and unchack all 4 option and apply your problem will be solve.
Dec 04, 2008 | Microsoft Computers & Internet
Problem with sony vaio keyboard
Sounds like you've got something stuck under your shift key. Carefully clean out under the keys, try a paintbrush and a hoover (on low suction if possible).
Be careful not to knock any of the keys off. They're held on by small clips which pop out or break easily.
Aug 22, 2008 | Sony Computers & Internet
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
CAPS LOCK
Often you can depress the caps lock and shift key simultaneously, holding down for a few seconds and that will unlock the caps lock
Nov 06, 2007 | Logitech 967233 Keyboard
Microsoft Windows XP Home Edition Service Pack 3  Full Version OEM for PC  Logo
237 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
