Vacuums
Problem for Vacuums
Generic problem for all Vacuums
How do you replace the
By lhawrot on Mar 26, 2008
How do you replace the belt? I took off the door and there
seems to be no easy way to get it over the lower red wheel.
Comments:
Mar 28, 2008
- Here is more information on the Bissell Proheat rug scrubber the model number is 8910-W the belt part # is 215-0628 & 015-0621. I am not sure what belt I need. I don't know how to replace the belt.
THanks.
Apr 09, 2008
- You were right about how to replace the belt But I had did take it to a repair person and she did it and part of the problem was there was a lot of pet hair in the brushes that broke the belt and she had to open up the whole machine and clean out the hair and pound back a metal cap that
got loose because of the pet hairs. So it did get complicated and
was more than the belt.
Thanks for you help and prompt reply.
Clarification Request
Posted by reddevil6 on Mar 27, 2008
Need to know brand and model number, they are different.
Best Solution
posted on Mar 28, 2008
Very Helpful)
reddevil6
Rank: Guru
Rating: 88%, 1776 votes
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Was this helpful?
Yes
No
Popular Solutions for Vacuums
Questions and Unsolved Problems for Vacuums
Answer
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way.... (More)
Answer
which steam mop to buy
Answer
wire reel
Answer
Does anyone know if i can get a replacement floor nozzle for my eletrolux z8220
Answer
I have a Eureka Altima vaccuum and it no longer suctions like it use to and also has a burning... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
