Question about Electrolux Ovens
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
  • 269 Answers
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
Posted on May 12, 2010
How do I stop an Electrolux double oven displaying a code F10 from beeping.
To cancel the F10 error, you need to unplug the oven or shut it off at the circuit breaker. Usually this error means that the oven is detecting a runaway temperature. Either the RTD (resistance temperature detector) sensor probe, the electronic oven (EOC) or the wiring is faulty.
You can check which one is bad by testing the resistance. The RTD sensor is on the back wall of the oven near the top of the cavity. It's somewhat easier to check the wire at the EOC. Unplug the connector and measure the resistance between the two wires. The resistance should be about 1100 Ohms in a room temperature environment. If you get the incorrect resistance, remove the sensor from the oven and check the resistance at the sensor. If you get the same faulty reading at the sensor and at the EOC, the sensor is probably bad. If the resistance is 1100 Ohms at the sensor, the wiring is bad. If the resistance is correct at all points, the EOC needs to be replaced.
Please add a comment with your oven's model number. I will try to find a source with the correct parts. I hope this helps.
Sep 20, 2015 | Electrolux 30" Built-In Double Electric...
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
May 02, 2010 | Electrolux Ovens
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
My bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Dec 09, 2009 | AEG Ovens
My AEG Electrolux fan assisted oven does not heat up. The lights and everything works just no heat.
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Nov 02, 2009 | AEG U3100-4 Electric Double Oven
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
362 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
