Question about Maytag Over-the-Range Microwave
Light won't go on; Model MMV1153WB-O
The light has stopped working on our over-the-counter maytag microwave. we have had the unit for about 6 months. For the life of me I cannot find where the bulb is located as I look over the stove top and under th unit. Does anyone know where where I look to replace the bulb? Thanks
  • Maytag Master
  • 9,047 Answers
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 06, 2010
Amana microwave/convection combo
most shops will charge you 60 to 80 bucks (they get it upfront) just to look at it to see what's wrong , me id do a bit of research to see what a replacement would cost , then using that info make a informed decision on how much to spend on repairing it , you could use the 75/25 plan if it costs more than 75% of new to fix it , then id buy a new one
what helps is that its a counter top model , they are easier to replace , as your not tied to a exact size as one would be in a built in model
Feb 09, 2016 | Amana Microwave Ovens
Maytag Microwave over the counter -error code SE
Banging on the control panel got it working would indicate a bad connection inside, not a short. Could be anything from a bad wire connection to a cracked solder joint on the main board.
Aug 23, 2017 | Microwave Ovens
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 12, 2010 | Emerson Black Microwave Oven
Microwave stopped working and was hot inside.
At just 13 months old I would be inclined to get in touch with Maytag. If you make enough fuss they will repair it under warranty. but just check that the air intake and exhaust are clear of debris first.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Maytag over the range microwave won't start
It sounds as if your keypad has failed.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & DIY help and/or an estimate.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Dec 05, 2009 | Maytag Microwave Ovens
The emerson microwave suddenly stops working,no power supply.
Two microwaves, 3 service companies and 6 service calls later, I think I have the answer. My unit is a MMV1153BAB but I'll bet the problem runs throughout the Maytag line. The units are ship from the factory set up to vent to the interior. If your want to vent outside, the fan in the right, rear, upper coner needs to be repositioned. Tell the service tech to go to servicematters,com and follow the link for technicians and find service pointer K8178715 issued in 2007. My unit has now run 20+ minutes with no problem and no moisture buildup.
Oct 15, 2009 | Maytag MMV1153A Microwave Oven
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Maytag Over-the-Range Microwave Logo
305 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
