Question about Janome Memory Craft 10000
Janone 10000 stiff handwheel...
The handwheel gets harder and harder to turn and also the motor seems to be straining during sewing. Machine is 5 years old. Same problem 1 year ago and dealer said "it needed a tune up" and all was fine. ($179) Now 1 year later...same problem. Also noticed belt material in bottom of machine.
Anyone else have this problem?
    Problem Solver:
  • 15 Answers
The 10000 has a design fault, Jim stutsman identified it shortly after the launch. though Janome still haven't admitted it. The belt runs close to a support arm, which over time starts dropping. This allows the belt to rub against the support arm creating the fine black residue. Another tell tale sympton is bird chirruping noises after you have been stitching for a time. Unfortunately it's not an area we can access easily, so it really does mean a visit to the dealer.
Posted on May 20, 2008
  • 106 Answers
The belt material in the bottom of the machine is there because the belt is slipping and wearing away because of the 'stiffness' this "stiffness" is also causing the motor to strain. If you continue to use the machine in it's current state the motor WILL burn out.
Could be caused by one or two problems or both.
Lack of lubrication oil/grease on all bearings in particular the handwheel bearing, this will be the "tune up" your dealer did.
Other cause could be thread that has somehow got wrapped round the handwheel shaft.
Unless you know how to get into the top of the machine and lubricate it yourself then it is back to the dealer. Same access to the machine is needed to check for trapped thread.
If you do take it to the dealer make him/her show you how to lubricate the thing yourself.
Best of luck
Rob
Posted on Mar 28, 2008
SOURCE:
Works sporadically. Why doesn't it have enough power to push new needle through material?
Difficult to say. The machine should have enough power to stitch fabric. Could be a problem with the foot control or the motor or multiple other issues.
Is the machine mechanical (NOT computerized)? If so, could need a good cleaning and oiling. If old oil has solidified and is freezing the moving parts, the motor would be straining so that any resistance (fabric) would prevent the machine from operating. Do not try to force the motor to operate as it could damage the motor. Consult your owner's manual. Use ONLY fresh good quality sewing machine oil. Do NOT oil any plastic, rubber, or belts. Open the top cover and the free arm cover and apply 1-2 drops of oil every place that metal rubs on metal. (Slowly hand-rotate the handwheel and watch where things move. Is the handwheel resistant to turning? If so, indicates something is holding it back. Does the oil loosen things? If so, you are probably on the right track.)
If the machine is not mechanical or you continue to have issues, might be best to take it for service.
Dec 01, 2015 | Singer Merritt 8734
JX2517. Why is hand wheel stiff and machine not sewing properly?
The owner's manual states in the Maintenance section (page 34):
"In order to prevent damaging this machine, it must not be oiled by the user...
If problems occur, such as difficulty turning the handwheel or an unusual noise, immediately stop using the machine, and contact your authorized dealer or the nearest authorized service center."
Sep 01, 2015 | Brother Sewing Machines
Handwheel is still "stiff" & it's getting harder to turn.
if you just got the machine back, call the man and tell him it's not working still and see what he says. some of the newer model are what is called self oiling.
Sep 09, 2014 | Brother Sewing Machines
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
Kenmore sewing machine starts, motor runs, bobbin winder works, needle erratic, handwheel very stiff
it could be a part is damaged or the machine may need some type of adjustment, a trip to the repair shop can tell you for sure..
Sep 07, 2013 | Sewing Machines
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
Machine jamming up
it could be a problem with the motor, you might need to see a repairman
Jul 30, 2010 | Brother XL-2600I
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
Sewing Machines Logo
427 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
