I need the power amp IC # for my Roland CPM 120 MKII.
Appreciate highly if someone can assist me.
Thanks a million.
Ravi
This is just a guess and the purpose is for you to get the datasheet and compare connections and see if they make sense... I have to do this often myself when documentation is unavailable.
Look up the datasheet for LM3886 on google and compare the package, electrical connections, etc. to see if that might be what is used.
MANY audio amps at this power level use this chip for the 50 to 68 watt range. They cost about $4 from the right sources.
If this is not what is used, the amp is probably in the TDA series of 5 and 7 pin TO220 style packages.
Other methods for these amps may involve class D switching amps and those usually use MOSFET transistors, not IC's.
