Question about Music
Need assistance in getting details of part number for power mixer
I need the power amp IC # for my Roland CPM 120 MKII.
Appreciate highly if someone can assist me.
Thanks a million.
Ravi
  • Music Master
  • 5,603 Answers
I tried to post a possible solution and it may have not made it so I will try again.
Download the data sheet for an LM3886.
This chip is used in a lot of linear audio amps in the 50 Watt range.
Download the data sheet and then check if connections on your unit make sense.
Smaller units sometimes use the TDA2050 7 lead TO220 style chip so look at that one in the LM3886 isn't the one.
Posted on May 09, 2010
Please! show me how to connect an electric acoustic guitar to the mixer
You can't. A mixer won't take the input from a guitar. You would need to connect the guitar to an amplifier and then connect the output from the amp to the mixer.
A mixer is what it is, a device to mix lots of incoming audio signals and mixing the volumes to a number of speakers.
The unit does contain pre-amps, but not to run a device.
http://www.prosoundservice.com/m9/MACKIE-CFX12-mkII--mackie-cfx12-mkii-12-channel-compact-sr-mixer-with-effects.html
Apr 17, 2016 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
Can you please tell me the best amp that I can use to hook up a Roland SPD 30, I'm looking for one to get volume. ( loud ).
Hi, With my sound engineers hat on I would use a small PA. mixer, amp and speakers!!!!
For quality you need a full, flat frequency range system with good headroom.
I assume this is for your own listening, when using an acoustic kit?
There are one box solutions.
  1. Drum amps. Like a monitor wedge with an amp, Roland do a PM-10, Various other makes are available.
  2. General purpose powered wedge.
  3. Keyboard Amp, these are full range and available in various sizes.
  4. Bass amp with high frequency driver (tweeter), not the best but will have good bottom end.
  5. Powered or active speaker, much like a powered wedge, but a different shape, needs an input volume control.
All these systems need to have large bass units, 10 inch minimum, and will be in mono. Two will give you stereo,
How loud depends primarily on the sensitivity of the speaker. But manufactures insist on selling things by power. Worth looking this up.
At a couple of feet away, 20 watts should do it, with high sensitivity speakers, more likely you find most things as above start at about 70 Watts.
Good luck, I hope I have widened you choices a bit.
All the best, Chris the Fader.
Oct 03, 2014 | Roland Spd-30 Drum Pads
Will amp still work after third prong is broke
If the third prong is the round one, then that is the ground to your amp. It will still work, however, the amplifier will not be properly grounded. So in a pinch you can use it, but you need to get the cable replaced. The ground wire is there for your safety, in case you plug your amp into a mis-wired outlet or if you are plugging in another instrument like a keyboard, mixer etc. that may be mis-wired. This could lead to a bad shock or worse. You have been warned.
Apr 22, 2014 | Roland KC550 Amp Keyboard
I need number ic power supply mixer soundcraft efx16
you are looking for a Soundcraft HB0166
Power Supply check it out here...
Soundcraft HB0166 Power Supply FX16 Full Compass
Jan 19, 2014 | Soundcraft Music
Hope you guys can help... I have a laptop Karaoke system. I connect from laptop to 6 channel mixer to speakers. I use a stereo phono to RCA from laptop to mixer. I am experiencing a buzz coming through...
Yep! Get a decent audio interface that attaches to the PC with a USB connection and uses BALANCED lines to your mixer. I use a UA-25EX Roland/cakewalk as an example. (about $200 and there are cheaper units such as M-Audio Fast Track MKII ) Note these interfaces BOTH record and playback with two channels for stereo.
Essentially the audio board that is in PC's and Laptops are too near the switching noise of the processor and some of that is just bound to get into the audio lines as they don't even have balanced audio lines from the computers. Make sure you use either TRS or XLR balanced cables from whatever interface you get. Also connect ALL interconnected equipment to the same power source or receptacle. You can try to reduce the buzz with the mixer EQ's with what you have, but that sacrifices audio quality.
Mar 30, 2011 | AMP Speakers Pro Karaoke System
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
This is just a guess and the purpose is for you to get the datasheet and compare connections and see if they make sense... I have to do this often myself when documentation is unavailable.
Look up the datasheet for LM3886 on google and compare the package, electrical connections, etc. to see if that might be what is used.
MANY audio amps at this power level use this chip for the 50 to 68 watt range. They cost about $4 from the right sources.
If this is not what is used, the amp is probably in the TDA series of 5 and 7 pin TO220 style packages.
Other methods for these amps may involve class D switching amps and those usually use MOSFET transistors, not IC's.
May 06, 2010 | Roland Mv8800 Production Studio
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Music Logo
88 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
