Question about Lavazza Espresso Point Capsule Machine
Lavazza EP 2302 is not working lights on but nothing is happening
When i switch on the machine the lights keep blinking but when in introduce the capsul nothing happen. I do not know if there is a problem with the pump or something elese.
first it overheated so i had to change one fuse but after that i am not able anymore to use it.
anw ideas??
thanks ben
5 Suggested Answers
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
tbreeze47
  • 3083 Answers
SOURCE: The part where you put the capsule in on my
I could find very little about this problem, but did run across one answer on Sovrana.com that might be of help:
The bottom drawer (where the spent cartridges are collected) is stuck:
The drawer has probably overfilled with cartridges. Part of the very limited maintenance of your Espresso Point should be to empty the refuse drawer daily (or more often if the usage is high) from spent cartridges. If the drawer is jammed, simple jiggle it while gently pulling it out. After a few attempts, the "cartridges" inside will settle and you should be able to completely remove it. Some cartridges may fall out, make sure you remove them before replacing the drawer in its receptacle.
You might try contacting Lavazza's support center to see if they have a solution, or have heard of this problem. Refer to the manual that came with the machine to get their support information.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 04, 2010
  • 8 Answers
SOURCE: I have a Lavazza espresso
Which of the Jaw spring is broken? Left of right, is essential to know, they are not the same. Where are you located? I have some parts or I could give directions to a dealer near your home. Guru.
Posted on Nov 20, 2011
  • 1739 Answers
SOURCE: need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Posted on Dec 18, 2011
Lavazza espresso point gets hot and light come on but nothing happens when I hit the green buttons.
Might sound simple, but If you insert capsule, you only have a certain amount of time to hit button and make one. If you take too long it kinda resets. Has hapened to me.
Jan 23, 2014 | Lavazza Espresso Point Capsule Machine
Lavazza does not steam
put in steam nozzle something like a long needle or something similar.
Dec 07, 2013 | Lavazza Espresso Point Capsule Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
My Lavazza Espresso Point keeps blowing one of the glass fuses, any adsvise?
Typically when this has happened I have found the issue being the plug holder and fuse block. Simply have the Plug Holder and Fuse Block replaced and the issue should be resolved.
Jun 10, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Our problem with the machine is every once and awhile the signal on the upper left side of machine that looks like a lightblub flashes and the machine does'nt work. It will stay on but not make coffee. ...
When the light flashes it indicates that the 130 deg themostat is open, machine too hot, however this does not prevent the machine from making coffee. Does the pump turn on? Do you hear a vibrating noise? Can you get water or steam, if so, the pump or the 3way valve are defective. Also, if after inserting the capsule and making a selection nothing happens, replace the micro switch. Good luck
Apr 23, 2009 | Lavazza Espresso Point Capsule Machine
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
414 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
