Question about Dell Inspiron 530 Desktop Computer
Cannot Display This Video Mode!!!
I did change by mistake to resolution of my monitor to resolution that do not support and now just can see the mensage on the monitor that say:
1: Auto Detect(analogo Input)
Optimum resolution 1680X1050
I did change the seting in a sefe mode... but works just on sefe mode. when I restart I will see the same problem again.
This is a Dell Inspiron 530 with monitor Dell 22"
Thanks for help.
A. Morales (apoloniomora)
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    In the safe mode uninstall the video card driver. This will reset the settings to lowest possible. After logging in reinstall the video driver. Video driver can be downloaded from Dell website.
  • 31 Answers
Restart your computer Press F8 key it shows Startup option choose VGA mode and Select the resolution after getting your desktop
Posted on May 06, 2010
Monitor mode
that is normal notification, which means your monitor doesnot support to higher resolution. so change screen resolution to 1600x1200 to fix this problem.
Mar 24, 2014 | Computers & Internet
I have a E152FP monitor will this work with a graphics card that has a DMS-59 connection
The monitor will work with that video card but the resolution needs to be set to 1024 X 768 or less. Your video card is trying to display the picture at a resolution that the monitor can not handle correctly so you get the video mode error. You will need to use the windows video settings screen to change the settings for that display than you will be good to go.
Sep 27, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
Not able to change the display mode to aspect at 1920x1080 resolution... but able to change the display mode to aspect @ 1680x1050 pls help... right now my screen is totally messed up.. i mean the display...
I'm not sure I totally understand the problem, but in general if you can't change to a higher resolution that indicates an issue with your video/graphics drivers rather than your monitor.
I'd try updating your graphics drivers (download the free program Speccy if you need help determining what video card you have) and then seeing if you can set your desired resolution after a reboot.
Mar 01, 2011 | BenQ G2220HD Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I want to connect my playstation 3 to my hp vs15. But after doing a little bit of research i am asked to change my display mode in order to get video from my playstation 3. hence my question is how do...
You change the video resolution at the video source, in this case, your PS3, not at the monitor. VS 15 has 1024 x 768 60Hz Maximum Resolution, so your PS3 cannot be higher.
You need to google 'how to change PS3 video resolution' If the PS3 resolution is set to high, the VS15 will display Out of range/format/video not support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 20, 2010 | HP vs15 15"LCD Flat Panel Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
I have now have a "video mode not supported" message on my L705 Hyndai monitor screen which came up right after I tried to change the resolution on my windows xp display. I can't get the monitor to show...
First connect you're monitor on to another system if possible. This will only make sure you're monitor is still working ok.
You're system needs to be shut down. (Keep you're monitor connected to you're system).
Than start it up and press the F5 key on you're keyboard every 2 seconds. This will bring up a screen that looks just like the one below;
Choose Safe mode from the list. Once you are in windows safe mode open windows control panel than open the display icon. Change the settings to where they were before you made changes. Chances are you need to lower the refresh rate and the resolution. Than save and exit the display properties. Close control panel. Cross you're finger and re-start you're system. If this doesn't work you'll have no choice but to hook up a much better monitor to you're system so you can change the display settings.
Cheers'
Mike
Feb 08, 2010 | Computers & Internet
QUESTION: Monitor says:
Reboot your computer and press the F8 key right before you see the XP loading splash screen. You should get a menu that lists things like safe mode and vga mode. Select the vga mode option and hit enter twice. This will boot windows into 640x480 resolution and will allow you to change the resolution back to 1024x768 at 60hz
Nov 23, 2009 | Computers & Internet
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
Dell Inspiron 530 Desktop Computer   Logo
601 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
