Question about Cell Phones
SONY ERICCSON P1i mobile - sms unable to create and hence unable to send.
  • 4 more comments
  • smd_bw May 07, 2010
    Dear Mr Jack
    Thankyou for the first feedback on Sony P1i. In addition to sms unable to create, new contacts or reminders also have a problem. I am unable to create. How to take back up on memory card.I have one card of 1 GB in my handset. How to take back up.
    Dear Mr Jack
    Thankyou. In the P1i handset- How to take backup using memory card.I have one memory card 1GB inside the phone. Can i transfer to that
    Sony Ericcson P1i - I have a problem in sms sending. After first alphabet handset hangs. I need to switch off. Same with entering new contacts and reminders. How to take backup of phone data to memory card.
  • smd_bw May 10, 2010
    Mr Jack
    I have backed up P1i user data with PC suite and also downloaded ,installed the SE update software.I have installed the update software on my mobile and also restrored user data.But the details have not come to mobile.Pl suggest WHY ??
    Dear Mr Jack
    Thanks for the fast reply. It;s not only the sms but the contacts also are not restored after my back up transfer. Could you kindly give inputs as i have very critical contacts and sms data
    Murali
    Dear Mr Jack
    Few more inputs from me. After installing the SE update on P1i, i am able to send sms. Problem is with backup not getting restored. The PC shows restore is complete. In the handset, the message Restore in progress remains. I need to pull out communication cable. The phone reboots by itself. But data is not transferred. Can you help me out, I badly need the sms es i had before
    Guru:
  • 1,049 Answers
First, check that your data plan has not changed, SMS becomes unavailable if texting on your phone is disabled by your provider.
If you have it or have been using SMS right along and it has stopped, you probably have a bug that effected some of the SE phones. To test it, restart the phone and see if SMS works again for a short period of time. If it works once or twice after restart then stops again, you have the bug. You simply need to back up everything (contacts, calendar, sms, images, anything on memory card... EVERYTHING) and manually update with SE Update Service (in the support section on the SE site...) to fix the issue.
Posted on May 06, 2010
  • 3 more comments
  • NA NA
    NA NA May 07, 2010
    You can do it with an application like MyPhoneExplorer. I don't think you can do it directly.
  • NA NA
    NA NA May 10, 2010
    I'm not sure, this model phone has had a lot of issues.
    I believe Sony Phone Explorer also is not really a Windows 7 application which leads to compatibility problems. You may need
    to set permissions or run in compatibility mode before it will even work properly on a Vista
    or windows 7 computer. They have been producing updates fairly regularly, but different revisions seem to be more and less compatible with different OS versions and software combination's and it is hard to know what will work for you.
    It may even just be a case of the system standards surpassing the phone. The synchronization app is badly designed and while most phones use WMDC and Activesync,
    which just works. The Sony Ericson version your using makes you
    chose whether your device is a phone to sync to, a device to install apps on, or a
    device to sync media and transfer files to every single time it connects.
    At this point it is probably sync and not the phone that is failing and that is hard to troubleshoot.
  • NA NA
    NA NA May 10, 2010
    I also don't understand totally the relationship between the sync software and SMS, which should be configured through the phone. But this also seems to be a common problem after updating.
  • NA NA
    NA NA May 10, 2010
  • NA NA
    NA NA May 10, 2010
    I'm glad you have SMS running again at least. If the restore won't run, there isn't much I can recommend to help with that part because I don't know if the original backup was even complete. You may very well lack the space on the phone to restore the data, or the data may have corruption from the old system which prevents the phone from rebuilding the message database.
    The utility I linked above is commercial, but it should let you read
    your contacts and SMS from the backup file you created to a flat file. Then you can re-sync them through your PC directly, or copy them back into Outlook, etc.
    Let me know if you have any other issues...and don't forget to review me when you get a chance.
    Thanks.
SMS backup for symbian-based phones
I think that's Win Mobile only software (couldn't find for UIQ or S60).
How about:
Sms Exporter (which is freeware):
http://www.softwaremobile4free.com/
It's the second program down.
Hope this helps,
Bill
Sep 04, 2009 | Lands Phones
I want backup of my sms's in my PC for p1i cell
which mobile u using if nokia then go for the nokia suite download it and take a backup of whole mobile to the pc
Mar 20, 2009 | Sony Ericsson P1i
My sony ericsson p1i cannot send sms...sms send failed
take out your battery, sim and memory stick.. then turn it off for 5 minutes, then turn in on without inserting the memory stick. after that try sending sms again, if it delivered,then try it with memory stick. if u can send sms,then its ok..but if cant then your memory sticks got a problem.my suggestion is to format the memory stick..
Jan 30, 2009 | Sony Ericsson K618i Cellular Phone
Unable to send sms on my sony ericsson W200i handset
take the phone or call your mobile providers to better assist you or do a master clear of the settings on the phone.
May 29, 2008 | Sony Ericsson W200i Cellular Phone
Dear sir or madam how to sms from p1i using laptop or pc?
Rob
no such facility in SE pc suit. you have to complain to Sony Ericsson web site in the future suits they might bring necessary updates for the same. i too initially worried about this as i was extensively using pc suit for sending SMS
Apr 27, 2008 | Sony Ericsson P1i
SMS Problem
I do have solution. Please read and follow information mentioned below. 1) go nd throw your sony ericsson phone to any toilet 2) flush the toilet nd den do **** on it happy now
Apr 21, 2008 | Sony Ericsson P1i
Mms settings My Phone is a Sony Ericsson P1i I really struggle to set up MMS setting I did followed the instructions in the instruction book and phone Sony Ericsson and Vodacom both told me I' will...
this is for danzljams..... I have P1i configured with T-Mobile in the USA.... They have details of this phone in their database.... if you call T-mobile they will text you the settings for MMS, WAP, T-zones, etc, etc... when you open the text the phone will install the settings automatically and you will be up and running.
Mar 23, 2008 | Sony Ericsson P1i
P1i sms using laptop
use my phone explorer for uiq 3.0 latest version
Dec 12, 2007 | Sony Ericsson P1i
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
