I have a colman evcon split unit, I had a guy replace the thermostat (old electronic, new mercury) and everthing worked fine. One week later out side unit stopped and was frosted over on the outside. I can push the contactors on the outside unit and got power. I traced wiring down to transformer. I replaced the transformer with one with a circutbraker built in. When i turn the brakers on the transformer curcuit breaker trips...I followed the wiring on the transformer to the best of my ability, help....
    President:
  • 1,515 Answers
Hi, you do have a dead short in the control side of the system. Good that you bought a transformer with the breaker. Most people don't and will smoke several of them. Anyway, it is a split system. If it was iced up, it must be a heat-pump, not gas fired. The problem will be in either the stat wiring from stat to indoor unit, to outdoor unit, and if a wire is not grounded in the stat wires, one of the 24volt controls have a dead short as the breaker trips instantly. Here is what you will need to do. You will need to do a process of elimination on all of the 24volt controls. I would start at the outdoor unit as you engaged the contactor by finger to check for power. If you see no stat wiring outside touching, the coil on the contactor is 24 volts and may be the shorted control. Coil could be bad. Pull a wire off the coil,there will be 2 wires at the sides. I am sure you know which are the low voltage controls if you can replace a transformer, this is great. You can find this pretty easy. If you pull a wire off one side and reset the unit and the breaker does not trip, then you know the low voltage coil is compromised. If it trips, go to the next low voltage control as the 24 volt coil on the rsv ( reversing valve ) and unplug it. If you have the schematic handy, it will show you all of the componants on the low voltage side/secondary side of unit that you will need to check until the breaker stops tripping. This is the best way to find the culprit!! I have done this for 33 years as a contractor and I am sure you will find this short very soon by doing this. Here is a tip for you also. Sometimes on the transformers that have these tiny resets on them, will wear out pretty fast. What you can do is take a 3 to 5 amp automotive type fuse and on the 24 volt side of the transformer you just cut the red/ hot wire/24v. and crimp a female stak-on to each end of the wire you cut. Then plug each end onto the fuse.Use some electrical tape around it so any bare metal that may be showing will not touch and blow fuse. This is a good way to protect all transformers that have no breaker if you end up with a short. Cheaper to replace a fuse then to keep replacing transformers every time! The fuse will just blow and you can start looking for the short. Now on your unit you can go to the indoor section where the transformer is that you put in. You can eliminate the thermostat and control wiring to the indoor unit and outdoor unit real fast so you know where or which section the short is in. Just kill main power, now where your stat wiring terminates you will disconnect from the control board. Since you have a heat pump you will have more control wires to work with, so either draw a diagram or use the one on your panel to reattach. Remove the wires from the board that take off to the stat first and supply power back to it. If the breaker holds, you will know the short is either the stat wiring from the indoor unit are touching somewhere/grounded or at the stat.You will then know that's where the short is as you have narrowed your search way down. If it trips, you will do the same to the control wires that go to the outdoor unit. If you disconnect it at the board and it holds, you will know it is from the wiring there to the outdoor unit! So, you either have wires grounded from there out or a low voltage control part has burned out. If you remove all of the control/thermostat wires at the board to the indoor and outdoor unit and it still trips, the short will be in the indoor unit which will more then likely be the board itself. Yes sir, this is really a very easy fix for you and I feel you have the ability to do this checks your self. The short has to be on the low voltage side of the transformer as you have proved that! You traced it right back to the transformer secondary low voltage side. So, just take your time and follow my instructions the best you can, and you will find out which part of the system the short is in and then narrow the search down further! I have a hunch the coil is burned/shorted on the contactor :) A place to start by pulling one little wire off the coil. I know this is a long explanation but I wanted you to understand and help you as much as possible on how to tackle this. Sounds difficult but it is not at all. It is either a low volt componant on the outdoor/indoor/ thermostat/ or stat wiring. If none of those, with all low voltage wires removed at board and it still trips, the board is shorted to ground. You can kill power to indoor unit and carefully take the board loose to look at the back side for any hot spots and you will know its the board. I had one totally smoked on a 5 ton package heat pump yesterday in fact!!! I could not see it until I pulled the board/defrost board out far enough to see it, but I knew it was the problem as it would not control the reversing valve, fan control, or run the condenser fan motor. Please drop me a line and let me know how you are doing, please. I would love to know that you were able to find it as I know you will. Best of luck to you.
Sincerely,
Shastalaker7
Posted on May 06, 2010
  • Robert Horton
    Robert Horton May 08, 2010
    Hi there, just checking back to see how its coming along. Please keep me posted.
    Shastalaker7
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Hi, I have an older mobil home with a Colman AC
Your unit uses both the capacitor and a contactor (relay) to start your compressor and motor. With the indications you are giving it would either be the capacitor or the contactor - and since you have already changed the cap - then replace the contractor!
NOTE: We always recommend that you change the capacitor and relay at the same time, because they seem to fail at about the same time.
Jul 28, 2011 | Coleman Heating & Cooling
When the unit is put in heat mode, but the thermostat is turned down below current temp. (Not calling for heat) the aux heat comes on anyway a short bit later and never cuts itself off.(Runaway) I replaced...
No, the most likely problem is that the defrost control in the outdoor unit is stuck and is telling the inside that the outside unit is defrosting and so the electric strip heat is turned on...
This could be a very complicated problem to get to the bottom of... I would recommend that you call a good tech to troubleshoot this as there are going to be quite a few wires to trce down to figure out exactly what is happening there...
heatman101
Feb 21, 2011 | Ruud Matching Split Air Conditioner
My house had the coleman evcon furnace and I am noticing everthing is getting a black film..what's the problem
could be soot needs cleaning , heat exchanger could be split , needs to be checked out
Jan 24, 2011 | Heating & Cooling
Colman evcon ''B'' relay connection on new programmable t/stat
Hello The B wire now goes to the O termnal on new thermostat.
Apr 03, 2010 | Coleman Heating & Cooling
Frig freezes up after a few weeks -- the glass tube looks fine
THERE IS A DEFROST SENSO ON TOP OF THE EVAPORATOR MANY TIMES IT WILL LOOK SPLIT WHERE THE WIRES GO IN THE BACK IF SO REPLACE IT
Dec 19, 2009 | GE GSS22SGM Side by Side Refrigerator
No heat at night
You have a poor low voltage connection from the thermostat or a bad contactor.The contactor is the main relay control inside the condensing unit. The incoming voltage wires connect to it.
Contactors are inexpensive. I would change that first.
Check all your low voltage wires in the condensing unit for loose connections.
Dec 11, 2009 | Coleman Heating & Cooling
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
