Question about Toshiba MR120 Remote Control
What are the codes for a yamasaki DVD player?
DVD region hack available?
no such thing exists
JVC HR-XVC1U region code - VideoHelp
www.videohelp.com/dvdhacks/jvc-hr-xvc1u/1143
  1. Cached
DVD Hacks > JVC HR-XVC1U region code hack. ... What are Blu-ray and DVD region codes, country codes, multi-region or zone locks? Read DVD Player ...
DVD Player and Blu-ray Player region codes - VideoHelp
www.videohelp.com/dvdhacks?dvdplayer...hits=25&listall...
  1. Cached
What are Blu-ray and DVD region codes, country codes, multi-region or zone ... 12382 DVD Hack hits, Showing 3276 to 3300 DVD Hacks ... JVC HR-XVC1U
JVC HR-XVC1U DVD Player/VCR Multi region hack ... - Fixya
www.fixya.com > ... > JVC > JVC HR-XVC1U DVD Player/VCR
  1. Cached
multi-region code hack is there a multi-region code hack for a Toshiba SD 370E dvd player? Can you help? I need the multi region code for my Toshiba DVD ...
JVC HR-XVC1U DVD Player/VCR Hack - Questions - Fixya
  1. Cached
will not play all regoins You need to hack the player to get all regions. There are a lot of web sites tthat carry the information you require. Some models dont hack ...
JVC HR-XVC1U - DVD Players - Retrevo
www.retrevo.com > Blu-ray / DVD Players > JVC Blu-ray / DVD Players
  1. Cached
JVC HR-XVC1U: No region hack for this player. Post region code/hack here. ... Harmony 880 w/ JVC HR-XVC1U VCR/DVD Combo- Help - Logitech Forums.
JVC HR-XVC1UC - DVD Players - Retrevo
  1. Cached
Learn more about the JVC HR-XVC1UC before you decide to buy. Download User ... www.videohelp.com. JVC HR-XVC1U: No region hack for this player.
May 03, 2016 | JVC HR-XVC1U DVD-VCR Combo
Compre un control universal mitsui y no se codigo para dvd yamasaki
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 07, 2016 | Universal Televison & Video
What is the multi-region code for Toshiba DVD Player SD5300KC
These WEB sites may have a region free code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 03, 2013 | Toshiba SD-3900 DVD Player
Unlock the DVD player
follow the steps. God bless you
    • 1 Find the unlock code for the specific make and model of your DVD player. Unlock codes for more than 6,000 DVD player models can be found online at Videohelp.com (see the Resources section).
    • 2 Write down the unlock code for the make and model of your DVD player. The unlocking process can be as simple as a short number code, but on some DVD player models, the code is a complex series of numbers to enter and buttons to press.
    • 3 Turn on your DVD player. Remove any DVD that is in the unit.
    • 4 Enter the unlock code for your DVD player exactly how the code is listed. On some units, enter the code by using the remote for the DVD player. On others, you may need to enter the code on the unit itself or with a combination of the remote and the unit.
    • 5 Turn off the DVD player after you enter the code. When you turn the DVD player back on, the DVD player should be decoded and able to read DVD discs from any region.
Nov 13, 2012 | Televison & Video
How to unlock mitsubish dd6030
follow the steps: God bless you
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
  • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
  • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
  • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
  • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
  • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
  • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
  • Jul 20, 2012 | Mitsubishi DD-6030 DVD Player
    UNLOCKING REGION 1 CODES
    see the following steps: God bless you
  • Jul 20, 2012 | Sony BDP-S360 DVD Player
    Unlock code for all region
  • Jul 20, 2012 | Televison & Video
    Yamasaki dvd 218 player - English User's Manual
    En México DF se consigue el control remoto original. Escríbeme: marcontr@yahoo.com
    Apr 04, 2008 | Televison & Video
    Region code
    My Dvd Toshiba SD-43HT when I put yhe dvd sais wrong region
    Dec 06, 2007 | Televison & Video
    Toshiba MR120 Remote Control Logo
    293 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
