Question about Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
Down load software for maxtor 9nx2a4-500 - Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
I have a Maxtor onetouch 4. I want to use it as an external hard drive. Windows explorer recognizes it but when I try to copy files to it, it says the drive is write protected. I down loaded the Maxtor...
That's because the software it comes with unlocks the drive to do backups. You should be able to format the drive in windows and then it should work fine for your purposes.
Right Click the Drive, Select Format, give it a volume name if you want and select quick format. Leave everything else default.
Comment back if you have any questions
Sep 11, 2011 | Maxtor OneTouch III Mini Edition 120GB...
The One touch software screen isn't appearing when I load
Hi.
You said 'when I load' so I hope this is note is relevant but I don't find the OneTouch (Maxtor Manager) software appears when the drive is plugged in either, so I think this is normal.
You should look for an icon (a capital M within a blue disc) for Maxtor Manager in the taskbar, at the bottom right of the PC's screen.
Please try right clicking on this icon (capital M), which should bring up a window with Maxtor Manager at the top.
Then click on the text 'Maxtor Manager' to open the program's window.
Hope this is what you wanted.
Jan 02, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
How to scan and rapair my maxtor ounetouch 4 Mini
sorry...my guess is ur HD is gone...
once it falls down and cannot be identified as a Hardware by the OS...most probably it's corrupt....
the HDD needs to be loaded / identified by the OS / mounted.... to be able to access it....scan will not work unless it's mounted by the OS....
take it to a tech shop a c if they can fix it...
May 04, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Only see's 33gb of 80gb drive
try down loading the hard dsk program from seagate/maxtor site, it solved my problem.
http://www.seagate.com/www/en-us/support/downloads/
Apr 15, 2009 | Maxtor Hard Drive
Polaroid digital camera i832 was working fine through USB cable. Received an Ipod shuffle for Mother's day, downloaded the software, loaded my Ipod and now my camera doesn't work. I'm think it's the Itunes...
the maxtor is your computers hard drive- the computer will also see your ipod as a hard drive-leave everything alone and use a memory card reader to transfer pics from card to computer-no software plug n play
May 18, 2008 | Polaroid i832 Digital Camera
Quantum Maxtor Serial Adapter
Though I suspected that I already knew the answer to your question about a source for drivers for the Maxtor 1394 CardBus Adapter, I wanted to research this in order to be able to provide PROOF that my answer is correct. As a result, I've now spent more than two hours researching this issue for you... As it turns out, the drivers you have requested are actually EMBEDDED within Windows itself, and have been ever since the release of Windows 98 Second Edition. They are listed within Windows as "OHCI 1394" drivers, which is another designation for FireWire / IEEE1394 device drivers. According to the Seagate / Maxtor Knowledge Base, there are NO downloadable drivers for the Maxtor 1394 Cardbus Adapter, and none have ever existed. The software originally provided on the CD in the retail package for the Maxtor 1394 Cardbus Adapter did NOT include drivers, which I'll explain in more detail later... As a general rule, when installing the Maxtor 1394 CardBus Adapter into a system for the first time, you insert the PCMCIA card into the Type II slot while Windows is loaded, NOT while the system is shut down; after inserting the card into an empty Type II CardBus slot, you should then hear a tone indicating that Windows has detected a device in the slot. The Add New Hardware Wizard should then load, and you might be prompted to insert your Windows CD into your optical drive, though this should NOT be necessary if you've previously installed any other FireWire devices on the same system. You can download the Installation Guide (in .PDF file format) for the Maxtor 1394 CardBus Adapter from either of the following links: http://www.seagate.com/staticfiles/maxtor/en_us/documentation/ins tallation_guides/1394_cardbus_installation_guide.pdf http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000 041641.pdf Simply right-click one of those links, and choose the "Save As..." option to download and save the Installation Guide to your Desktop, or to another folder where you can find it easily... The following links should help you to learn more; the first link explains the reason why drivers are NOT available for download for the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=831 The next link describes a known problem (and the solution) when the Maxtor 1394 CardBus Adapter is installed on some IBM Thinkpad laptops: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=1959 The next link describes the hardware and software requirements for installing the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=762 As I've previously mentioned, the original software (on the CD-ROM) provided with the Maxtor 1394 Cardbus Adapter were the "MaxTools" utilities (which I have NOT been able to locate for download); they were NOT actual hardware drivers for a Windows OS... Well, I hope this solves the mystery of the "missing" FireWire drivers; though I don't recall ever needing to load third-party drivers for ANY FireWire devices I've installed in a Windows system, I wanted to be able to PROVE to you (and to anyone else who reads this in the future) that the drivers are already embedded within Windows, and that they are NOT available for download. As long as you use a supported version of Windows (all versions beginning with the release of Windows 98 Second Edition), you already have the drivers available, though Windows will probably need to extract them from the Windows CD, if they haven't been loaded onto the system previously. Good luck with this; let us know if you have any problems installing your FireWire card. I don't think that is likely to happen, as long as you follow the steps in the Installation Guide. You might want to create printouts of those Seagate Knowledge Base pages (or copy them to your hard drive, or at the least, bookmark the individual links) for future reference.
Apr 01, 2007 | Quantum Maxtor Serial Adapter
Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
294 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
