Question about Tomtom GO 700 GPS Receiver
Hi i put a 12 volt charger by mistake into tom tom now it wont come on any ideas thanks
    President:
  • 1,851 Answers
You will need to send it to Tomtom now -it most likely fried the hdd.
Posted on May 06, 2010
How many volts I have a charger that has different volts which one to set it on I have a whistler 1610 just trying to put the charger on the right voltage
Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
May 21, 2014 | De-1610 Radar Detector With Car Charger
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
With new battery john deere toy tractor wont work. Any ideas for an trouble shoot?
check tha battery and charger with a multimeter and make sure they are showing at least 12 volts
Aug 30, 2011 | Peg Perego 12 Volt Rechargeable Battery
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Need to increase voltage on powersuply
Hi John.
No idea why your post is under monitor problems ???
I figured you need an adapter mod for a monitor !! SO don't kill my ratings since this is not my area of expertise, but I can try to give you some input anyway, not so much a solution !!.
I would NOT recommend altering a 12 volt adapter for charging a battery especially if it is a standard ac adapter.. You may get it to give you 13.8, but your amps may be wrong.
Battery charger depends on type of battery also. Don't know if you are using NIMH or Nicad or acid based ?
The differnt style batteries use different type chargers. Wrong charger will burn up a battery or blow it up !!
If the battery is a 13.8 then normaly the charger would be putting out 2+- volts more than the battery rating. If you battery is 12 then a 13.8-14 would do the trick. (12 volt car batteries for instance take a 14+ volt source to charge them)
I would recommend looking here
http://www.powerstream.com
They have all those goodies and may give you an idea. for what I think you are doing.
Fran
Oct 17, 2008 | Computers & Internet
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
147 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
