Problem for Projection Televisions
Generic problem for all Projection Televisions
Hitachi 53uwx10b Convergence
You know how on some TV's you can go in the settings and pop up a grid on the screen and align the colors? How do you do that with this TV?
Thank you.
Comments:
Mar 27, 2008
- Now, that's what I was looking for. Thank you very much.Mar 27, 2008
MikeNJ1964, You ROCK!! That's exactly the info I was looking for. Seems pretty straight forward. Thank you very much.
Nov 18, 2009
- MikeNJ1964, I finally got the nerve up to dig in and see if I could fix my problem. With the repair kit from TVRepairKits.com all went just fine. TV is back in business!! Thank you for all your help and input.
Same Problem
Jan 01, 2009
-   It seems I have convergence issue (after reading posts here). Is it possible that the television just needs this adjustment and not parts? The set has been working fine and then *poof* the left side started ghosting pink/green. I found a loose wire. It seemed to straighten up. Then it started ghosting again. I had the SDKs replaced about 5 years ago. Do they just go bad ever few years? Thanks-
LMC1 Dec 22, 2008
-   that was helpful the first time, but now i cant get it to go back so i can finish it. when i press magic focus the second time it goes back to the tv.-
hiff
Best Solution
posted on Mar 27, 2008
Rank: Guru
Rating: 89%, 744 votes
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Popular Solutions for Projection Televisions
Mitsubishi WS-55511 55 in. Rear Projection Television
1 Solution
Hitachi 43UWX10B 43 in. Rear Projection Television
1 Solution
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
1 Solution
JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
2 Solutions
Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV...
1 Solution
Questions and Unsolved Problems for Projection Televisions
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS...
(More)
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS EXCELLECNTLY NEVER HAD A PROBLEM WITH IT. NOT USED AS MUCH AS A FAMILY ROOM TV, WHICH ARE ON CONTANTLY. WE WERE TOLD THAT THESE WERE NOT OPTIMUM FOR GAMING THAT WAS FINE FOR NOW. WE ARE LOOKING TO REPLACE IT WITH A LCD. WHAT WOULD BE A GOOD SELLING PRICE FOR THIS OLD UNIT.
how to connect hd converter box and dvd player
how to connect hd box converter adn dvd player
Foxsat HDR box switches on then switches off
I have an RCA 40'' D40W135DYX1 rear projection TV that one day stopped turning on. After...
(More)
I have an RCA 40'' D40W135DYX1 rear projection TV that one day stopped turning on. After troubleshooting several days I figured out that you can turn it on with the power button, but not the remote. I had the buttons locked at that time, if you the power button then you could turn it on with the remote. Once on everything works fine. You can even turn the TV right back on with remote within a certain time. Any ideas?
