Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
I have a rinnai avenger 25TR and i've just relocated it to our new house. When i tried to turn it on, it shows a error "12" and switches off.
  • mrimmer369 May 06, 2010
    Thanks. How do I bleed the air out of the system?
    I have just thought of something that may be material. The "old" location was off bottle gas, but the new house has gas from the mains. Does that make a difference?
    Novelist:
  • 135 Answers
Good Morning,
I am attaching a link, it is the installers guide,
there are a couple of things that I would check first, did you bleed the air out of the gasline before trying to start the system? Another common issue is the polerity of the electrical plug, reverse the plug leads, it is very common with units that have computer boards to lock out, and since it is in a new location, reverse the plug wires and then follow the reset proccedure in the manual.
Please contact me back if I can help you further. Have a great day.
Sincerely,
Paul Gibson
Follow this link: http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/674.pdf
Posted on May 06, 2010
  • Paul
    Paul May 06, 2010
    Oh, Yes,, that is a major problem! Natural gas operates at 3.5 pressure and propane operates at 11.5 to 12 pounds. So what is happening is that the safeties are working and shutting the system off. The only way to fix this is to buy a propane to natural gas kit from Rinnai or a Rinnai dealer, and then change out the orifices and spring kit.
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
I have an Rinnai Avenger 25TR heater. The problem is that the heater ignites, it starts, but then it turns off. A red light then flashes and the number 13 also flashes in the bottom right hand corner of...
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a Rinnai Avenger 25TR. There is a smell of gas, what could be the problem.
leak on the heater , could be on the pilot supply or the valve at the control tap , burner could need cleaning , try some soap water round the joints use a small brush joints will bubble if leaking
Aug 12, 2010 | Rinnai Heating & Cooling
Rinnai Avenger 25 error 13!
thermocouple high cut out on convection fan rinnai fitters job , have to wait sorry , it is in the manual under fault codes .
Jul 06, 2010 | Heating & Cooling
I cannot get the Avenger 25TR to turn on
Heres a link for the manual for you direct from the Rinnai web site.
Hope you already got this fixed. A good safe heater this one.
Bit biased i suppose as I work for Rinnai.
Have a good day.
May 14, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Locked Rinnai Avenger 25TR heater
If its Displaying a Little key Picture, all you have to do to unlcok it is Hold the Up and Down Button until the heater beeps and it will be unlocked.
Jul 28, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai Avenger 25 ,brand new ,will light and start, then go out
Temperature sensor is faulty.
Ring them. its under warranty.
Jun 10, 2009 | Heating & Cooling
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
May 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
131 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
