Question about Compaq Presario 5000 PC Desktop
Installing more memory
Can you give me step by step ins. on how to install more memory in my compaq presario computer?
  • 4,102 Answers
Hi if you go to this site first www.crucial.com
then look on the site and it will then scan your computer for you telling you exactly what memory you need like p100 or p133 as getting the wrong one will cause your computer to stop working ok.
also the site will tell you the maximum memory you can have dont go above this as you will get alot of problems with your computer.
Once you have the memory ready to install follow these instructions ok
1. with computer off and switched off at mains remove the outer case
2 once case is removed you will see all the slots that your monitor and keyboard plug into their will be a strip of slots near these these are all for modems monitors etc.
But if you look at the memory you need to install then youll know what they look like the slots for the mem will be away from the other slots for monitor and keyboard etc once you have located the slots you will see either one or two memory cards in these slots.
3. one slot will be p100 and one p133 but the site i told you about will show you this.
4 remove the memory chip thats in their their will be a clip at each end push these back and it will lift up the memory strip a little bit then pull it out ok. On the one you take out it should have a sticker on it somewhere saying the size and whether its p100 or p133 remember witch slot it comes out of ok
5. if theirs only 1 in your comp all ready and your only putting one in then you wont need to take the one out thats in if this is the case then all you need to do is insert the new memory it will only go in one way make sure you push it down hard enough so the clips can close at either end.
6 if you do need to take the one or two out thats all ready in your comp then write down witch one was in the slot ie 256mb p100
and whatever the other one is thats in their if their is 2
remove these.
7. Check the memory your putting in make sure you have the right ones ok but that site will tell you what you can use ok.
push the new ones into the slots untill you can close the clips at either end ok.
8. Once you have put them in its best to leave the case off whilst you try them to check their in ok.
plug your monitor and keyboard back in plug everything back in thats usually in their.
9. Now switch on and when your comp comes on if their in right youll get a message before windows boots up saying memory increased to what ever size you have put in check this is correct and is the same as the chips you put in ok if their the same then ok these new settings and then your comp will boot up as normal.
Check your computer by opening up the internet just to check it all works ok without freezing or shutting down.
If everything is ok then put the case back on your computer and then the jobs done you dont need software or anything like that ok.
If you have problems or the memory is wrong when it boots up like say you put 1gig in and on the screen its telling 256 then you know this is wrong so shut it down again then swap the memory cards around as they might be in wrong slot dont worry if it is this wont damage your computer.
And also shut down if when your computer comes on it freezes up or shuts down or comes up with error this can be that their in the wrong way round or it could be that the memory you have brought is not compatible with you computer ok.
But if you use the site i told you about it will tell you exactly what compatible with your comp if you follow this you wont go wrong ok.
Most people who get it wrong get the p100 or p133 the wrong way round causing the computer to freeze.
The best thing to do is remember or write down where the memory is now in your computer incase you get any problems then you can put it back as it was before changing memory then you know your computer is still going to work the way it was before.
If you have any problems or questions then let me know then i can assist you further ok.
1 remove case
2 look for the memory strip
3 remove old memory make note witch ones p100 or p133
4 insert new memory untill you can close clips
5 switch computer on check its all working ok
Remember to earth your body out before touching the memory as it can blow the chips ok touch some metal that goes to earth like radiator anything that will remove the static from your body ok.
Let me know how you get on ok
Posted on Mar 26, 2008
    Sergeant:
    Champion:
  • 329 Answers
Check first if you have a free slot to your memory. so you can make sure you can upgrade your PC.
    Scholar:
  • 35 Answers
You will want to make sure you remove the existing memory and bring it with you to buy the upgrade. You will want to try to buy the same brand and type. there are two screws in the middle of the bottom of your laptop use a tiny phillips and pull the cover and you will see the memory modules. there are tabs on either side of the memory you can release the memory with these and it should pop up. on mine i replaced the 2 modules with 2 new ones 2gb each and put the old ones in my junk collection for a rainy day. the 4gb only cost $75 total at frys and they were pny. you may want to remove one of them and bring it with you and ask for help buying it.
  • Cary Micheau
    Cary Micheau Mar 26, 2008
    sorry i did not see the desktop part before i wrote but being a desktop you can just remove the cover screws and pull the cover off and pop out the memory they plug in very easy
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Compaq Presario v2508 Multiple BSOD errors
so you need to reset cmos as memory modules must be out. is a virus instaled on mainboard so only way to recover control is these steps:
1st take the hd out.
2nd reset cmos
3rd take memory out
then put windows install cd and install as 1st time on computer, dont attemph to loading windows, or else you need to repeat-it again. then install laptop drivers, then test.
Jan 09, 2010 | HP Compaq Presario V2508WM (EP386UA) PC...
I want driver for compaq presario c700
u should always turn off automatic updates off your windows.......and install drivers it will be work fine..
I will give u all drivers link....go to hp.com and search it..
for modem -sp33442, for audio-sp35270, for sm bus controller-sp36492, for quick lounch sp38171, for UAA sp32395, for webcam sp37849, download all drivers and install it.
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:\swsetup\sp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
wifi driver link:
http://www.atheros.cz/download.php?atheros=AR5007EG&system=1
good luck
Feb 23, 2009 | Compaq Presario 700 470024-192 Notebook
Driver Compaq Presario C700 notebook
Only for windows xp steps........
u should always turn off automatic updates.......and install drivers it will be work fine..
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
Click on Finish..
wifi driver link:
good luck
Jan 05, 2009 | HP Compaq Presario C700T
Install memory
Use the following steps to remove a memory or continuity module:
Turn off the computer.
Windows 98 or 2000: Click Start , Shut Down , and then Shut Down
Windows XP: Start and then Turn Off .
Unplug the AC adapter, if present, and remove the battery.
From the bottom of the computer, remove the screw holding the RAM cover, and remove the cover.
Remove the board by pulling it away from the connector at a
45-degree angle.
Align the keyed (notched) edge of the board with the keyed area in the expansion slot. Insert the board into the slot at a 45-degree angle until it is seated.
Push the front edge of the board down until the retention clips snap into place. Then replace the cover
Aug 25, 2008 | Compaq Presario Notebook
Memory
I FOUND A SITE TO GIVE STEP BY STEP INTRUCTIONS TO PRINT ..YOUR INFO WAS VERY HELPFUL THANKS ALOT
Apr 04, 2008 | Compaq Presario 5000 PC Desktop
Do I have proper memory bought to install?
you can add the memory if you have additional slots inside the machine..open it up,and inspect the number of memory slots
Mar 22, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Compaq Presario 5000 PC Desktop Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
