Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 blinks 4 times
My Sony KV-32FS120 wont power up, LED blinks four times, replaced the Vertical Deflection Booster(IC561), still dead.
  • Brad63ford Mar 29, 2008
    My Sony KV-32FS120 blinks 5 times and I can't find a solution.
  • 129 Answers
Good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Posted on Mar 28, 2008
SOURCE:
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
Sony crt tv (KV-BZ14M70) led blinking four times in stand by mode, so it means?
Hi Ullah,
LED blinks four times on KV series means that the Vertical deflection circuitry encountered a problem. You can repair it yourself if you have knowledge in electronics, knowledgeable in soldering and desoldering of parts on the board.
[email protected]
Jun 14, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
KV-34hs420 LED Blinks 4 times
Apr 28, 2012 | Sony KV-36XBR400 36" TV
Sony KV-20Fs100. Same problen as #4620488. TV
4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button doesn't do anything, remote doesn't work, 4 blinking lights. Sony kv 36fs120.
you have power issue. short the prongs for a minute. then remove the short wire. then test. if not succesful go to your nearest service center.
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Go to turn on blinks green like normal then turns on real quick moment than shuts off and blinks red 4 times pause four times
According to the symptom on A Board +13volts not being supplied, and this is due to IC561 Details(Part No. and Description) of IC is given below:
8-759-980-58 IC TDA8172
which is not working please replace it and your tv work fine again.
Thanks for using fixya.
Nov 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV 32FS120
Hiii...
I'm not certainly sure how many time the led blinking ?
I hope hear from tou soon...
Thank's
[Vrya]
[email protected]
Feb 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
578 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
