Question about DeLonghi MW 605 Convection/Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
All lights and timer works but does not heat food or defrost food. Grill does not work iether. Have had the oven for only 2 years and it is not used heavily, mainly for reheating plated food.
    Sniper:
  • 92 Answers
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Posted on May 06, 2010
How set clock on oyster microwave and grill?
Oster Microwave Oven Operating Instructions
  1. Press the "Clock" button once, then the correct number buttons to set the desired 12-hour time. ...
  2. Press "Timer" to set the timer function. ...
  3. Press the number pads to select a cooking time. ...
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. ...
  5. Select "Speed Defrost" to defrost food quickly.
More items...
Oster Microwave Oven Operating Instructions ' Hunker
https://www.hunker.com/13407971/oster-microwave-oven-operating-instructions
set clock on oyster microwave and grill Google Search
Jun 24, 2018 | Microwave Ovens
Mircowave works but doesn't work for heat/grill defrost etc
1.check fuse
2.check relay (microwave oven magnetron)
3, check switches of the doors
May 11, 2014 | DeLonghi P90D23EL-B1A Easi-Tronic Solo...
My delonghi ac925chs combination oven and grill work... microwave has stopped heating have noticed there is no light on in the microwave.and when i went to use it yesterday it would not heat in the...
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Sep 04, 2011 | DeLonghi Microwave Ovens
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
DeLonghi MW 605 Convection/Microwave Oven Logo
1,665 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
