Washing machine runs through program but pump continually running causing machine to constantly fill with water
  • 141 Answers
May be the inlet valve might be open due to usage kindly replace the inlet valve your problem will be solved
Posted on May 06, 2010
I have a W 2104 washing machine , the program seems to not work properly , when the water comes in it straight away pumps the water out again and repeats this cycle
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
On some models that have belt drive the WIGWAG selenoid could be defective or the spin and agitate bars could be bent or worn, or the spring worn or broken.
By the way my advice is free cuz God is good!
Mar 24, 2017 | Washing Machines
I am not getting any display lights, the controls on the front of the washer do not work and when its plugged back in it is constantly running the drain pump
Jun 12, 2015 | Washing Machines
I have an Estate heavy duty top loader that continually fills then drains and constantly runs water never initiating wash cycle
Apr 26, 2014 | Estate Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Whirlpool Clothes Washer Water Level...
Sticks on drain cycle and cannot be stopped
Water constantly running down the drain, and the washing machine repeatedly topping up with water, can be caused by faulty plumbing. The washing machine may get stuck on a wash, or rinse program, caught in a cycle of filling with water and losing it down the drain. When siphoning has started it can stick forever in this cycle. NOTE: These symptoms can also be caused by totally different faults. Indesit washing machines (and some others) for example can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor). The main difference is that in this scenario, the water is being pumped down the drain and the water pump can be heard running, whereas in siphoning, the water is just running down the drain through gravity.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. It's exactly the same principal as siphoning beer out of a barrel into bottles or siphoning petrol from a tank. If the end of the drain hose is very low, then water can siphon out as soon as it enters the washing machine. If it's just slightly lower than it should be, then siphoning is usually triggered when the washing machine first pumps water out or even just occasionally.
This fault most often occurs when the washing machine has been moved out for cleaning or relocated in a new house etc. It can also occur if a drain hoses stand pipe isn't properly secured to the wall and falls over at an angle.
The drain hose should also not be pushed down too far down into the waste water pipe, which can cause siphoning just the same as if the stand pipe is too low. It needs to go just far enough in to prevent it falling out but it will fall out if not secured properly with a crook or tape. If the stand pipe that the drain hose is being pushed into is too low, then it may need raising. It could have fallen through the floor boards in which case you can gently raise it and secure it to the wall with proper brackets. If it was just installed too short, you can add a small extension piece.
You should ensure that the plastic crook supplied with the washing machine is fitted to the end of the drain hose. This forces it into a shepherd's hook. The length of drain hose sticking out of the crook should be about 4 or 5 inches. If the plastic crook is missing, I tape the drain hose in.
You could have a bad drain pump solenoid.
Mar 07, 2010 | Dishwashers
Drum not filling up with water, it's draining straight out.
That means that the drain pump is always on.
That can happen because of a faulty or stuck water level switch (the one with floating sensor), because of a faulty drain pump solenoid, or because of a faulty pump.
Oct 24, 2008 | Washing Machines
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Water runs out
check for your drain hose too deep in drain causing a siphon on the water as it fills
Feb 12, 2008 | Washing Machines
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
