Question about Logitech Harmony 900 Remote Control
I am trying to set up an Activity for teh first
I am trying to set up an Activity for the first time. I have gone through the Wizard twice and set up Watch TV. The TV doesn't turn on, the Amp goes to AV when I have set it to TV and the Sky Box doesn't turn on. What can I do? My TV is a Panasonic and needs the On/Off toggle held down for a few seconds before it 'takes' how can I adjust that? Maurice Gallagher 0044 208 9096
  • 2,335 Answers
I can help you troubleshoot your Logitech Harmony 900 remote control Activity.
I know firsthand that some Activities work perfectly the first time they are set up, while others need to be finessed manually.
By heading back into the Harmony Setup routine, you can choose to edit and customize what your remote is doing during its Activity procedure. Once you are viewing the individual steps that the Harmony 900 is doing, you can repeat commands, enter pauses, and tell the remote to do 'the same thing' a different way. This last bit I have found helpful for changing inputs and turning devices on for example; you will find once you are editing the commands manually, that you can scroll through many pages of every command the remote can send for that particular device. Some of these commands seem like duplicates, but they are actually different ways the remote can do 'the same thing', and the setup doesn't always choose the correct choice the first time.
I hope that helps.
Posted on May 06, 2010
I have a 2005 Nissan Murano SL. I was in my car for the 2nd time of the day and all of the sudden display reads Eject Disc. I try ejecting discs and it does nothing. I trying switching discs and display...
Sounds like the changer has gone bad. Same thing happened on my Altima twice. Dealer replaced it under warranty. Guessing yours is no longer under warranty. Unfortunately this is more of a replacement than a repair item. Your choice if you go factory or aftermarket. I'd see if you can go with the 2007 stereo since it supports MP3 discs and teh 2005 did not.
Dec 29, 2010 | 2005 Nissan Murano
It is a HP Photosmart C4780 All-in-One Printer and while instaling teh printer to teh computer wirelessly teh printer is giving a static IP of 169 both RPC and reset on teh printer has been done still the...
to install the printer wireless, you first need to tell that is it for just one computer or more than one ? then the computer you want to install it on, you will first have to start the installation from the CD and connect the printer with the help of the USB cable with it, then once the wizard asks you about the wireless option then select it and when the computer asks you to disconnect the printer cable, then do that.
Also check computer firewalls and anti-virus to allow it.
Thanks. If this was helpful, then kindly rate me.
Nov 05, 2010 | Office Equipment & Supplies
When powering on using the harmony 670 remote, it changes the input type from HDMI to cable
You probably have the input selected to cable for the Activity that you are using.
In the software, click 'Settings' beside your activity then click 'Review the settings for this Activity'. Then, go through the setup wizard and make sure the input for the Activity is selected as 'HDMI'.
Apr 01, 2010 | Logitech Harmony 550 Remote Control
The CD/DVD burner on my laptop will only burn CDs. I want to put my pictures on a DVD but it won't let me. Any suggestions?
Please try following steps:
1. Make sure you are having a CD/DVD burner, not the combo drive.
2.Reinstall teh burn engine.
3.Type regedit on run option and browse the following apthe
H_Key_loacl machine/system/current control set/control/class/first value starting with 4d and gthen single click on the value.
On teh right hand pain search for the lower or upper filters. If anyone or both are there just delete them.
4.Go to device manager and uninstall the secondary IDE/ATAPI controllers .
Restart the system twice then check. If not working time has come to change your optical drive.
Mar 09, 2010 | HP Computers & Internet
Unable to update remote Gat a new tv and proggamed it in the software but when I try to update remote I get the message Assertion failed Application-defined or object-defined error (1) Context harmony...
Run the Activity wizard, one at a time, for all of your Activities.
  1. Launch the Logitech Harmony Remote software and login to your account
  2. From the Harmony homepage, select the first Activity listed and click on the Settings button for it
  3. Select Review the settings for this Activity and click on the Next button
  4. Select No, I want to run the setup wizard again to change these settings and click on the Next button
  5. Move through the wizard by clicking on the Next button to move to the next page, ensuring that all questions have been answered correctly. Usually a setting will be unselected, causing the error
  6. Repeat for every Activity in your account, attempting to update each time to check if the error has been corrected
Jan 27, 2010 | Logitech HARMONY 659 Remote Control
Everything works except no picture of tv
The Television may be out of synchronization with your remote or may be configured incorrectly.
1. In front of your Television, press the Help button on your Harmony Remote.
2. Answer No when asked "Did that fix the problem?"
3. The Harmony will then ask, one by one, if all of your required devices powered on when the Activity was started. Answer Yes or No until all required devices are powered on.
4. Answer No if the remote asks if the TV is set to the correct input needed for the Activity. In this example Input 4 is used, though this may vary from your setup. If the TV switches to another input but no picture is seen, continue answering No until an image appears.
5. If you now have a picture on your TV screen, answer Yes when asked if the problem is now fixed. Your television was simply out of synchronization with your Harmony One and should now work correctly. Please try switching between your other Activities to see if they switch correctly. If this has not fixed the problem, proceed to the next section Confirming your Activity Settings.
To confirm your Activity Settings, please follow the steps below:
1. Launch the Logitech Harmony Remote software and login to your account.
2. Click on the Activities tab on your home page
3. Click on the Settings button for the Activity you wish to troubleshoot.
4. Select Review the settings for this Activity and click on the Next button.
5. Confirm the input chosen for your television is correct. Select No, I want to run the setup wizard again to change these settings and click on the Next button.
6. Click on the Next button through the Activity setup screens until you arrive at the screen asking the question "What input or channel does your ... TV need to be on? From the list, select the input that the TV uses for this Activity. Once finished, click on the Next button.
**NOTE: It is recommended to perform these steps for all Activities that use the television.
8. Click on the Done button on the Set Up Activities: Summary page.
9. Click on the Done button on the "Select the Activity settings you would like to modify" screen.
10. When you have finished, click Done to save your changes.
11. Click on the Update Remote button to update your remote.
Jan 17, 2010 | Logitech Harmony 966208 Remote Control
HarmonyProcess error '800a0005' Invalid procedure call or argument /EasyZapper/New/ProcLogin/Start.asp, line 133
WHEN LOGGING IN
Cause:
Comunication error with a Logitech server.
Solution:
You will need to completely exit out of the Harmony software and re-launch it. To do this:
1. Quit the Harmony software
2. For Windows base PC's, right click on the Harmony icon from the system tray and click on Exit
3. For Mac, quit the software by clicking on Logitech Harmony Remote Software menu at the top of the screen and then clicking on Quit 4. Logitech Harmony Remote Software
5. Open the Harmony Remote Software
You should now be able to login.
WHEN UPDATING
If you are still unable to resolve your issue, let me know
Jan 10, 2010 | Monster Cable Monster Central 121161...
Installation-2nd time
Do you have a username / password to connect to teh internet ? If so, use it on the router. Else, use the clone MAC address option. that should help
Thanks Ranjit
Oct 07, 2009 | NetGear RangeMax WPN824 Wireless Router...
Logitech Harmony 900 Remote Control Logo
32 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
