Question about Nixon Super Hero Ss Ii Black Watch
How to set the analog time on Nixon Super Hero Ss Ii Black Watch
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Posted on Mar 15, 2009
SOURCE: cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Posted on Aug 11, 2009
escapement
  • 2334 Answers
SOURCE: how to set the time on Nixon Game over watch
Follow this link: http://www.nixonnow.com/manuals/index2.html This is all what NIXON is offering for download. Rate me, plz.
Posted on Jan 28, 2010
escapement
  • 2334 Answers
SOURCE: How do you set the time to the Nixon 51-30 watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Nixon watch manuals. To stop the crown to come off it must be screwed and secured onto stem. If you are not sure how to do that, visit your nearest watch repair shop and they will do it for you. Rate me, please.
Posted on Feb 26, 2010
What type/kind of battery do i use to replace in my super hero ii ss black nixon watch
Take your Nixon watch to a jeweler to have the battery replaced.
Apr 24, 2017 | Nixon Watches
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
User manual for nixon delta pu watch
Here you go,
http://www.nixon.com/manuals/nixon_delta.pdf
Apr 07, 2012 | Nixon Delta II stainless steel PU Digital...
I need a couple of extra links to my black and silver Super Rover
mcdevito75 here, BEST BET, look for a small watch repair shop in your area, chances are you"ll have to order these links from Nixon watch.
Jul 12, 2010 | Nixon Super Rover NIX0123
I change the battery of my nixon superhero TI/PU and now i cant see the digital numbers what can i do??
you need to restart digital part of the watch. Open it ( the screws part) and there you will find 2 reset contacts. You need toen close the contacts with the big battery in it. Then it should start working. This acion have helped me few hours ago.
Jun 19, 2010 | Nixon Super Hero Ss Ii Black Watch
Time
Hi Terena,
You're not a numpty! :O
Just go here:
http://uk.nixonnow.com/home/
MouseOver 'Support' and click 'User Manual', choose your model and follow the instructions to set your watch.
Hope this helps!
Chris (ziraffa)
Dec 26, 2008 | Nixon Key Men's Watch - Gunmetal Dial -...
Nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
Feb 14, 2008 | Nixon Super Rover NIX0123
Nixon Super Hero Ss Ii Black Watch Logo
246 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
