Question about SNK Fratelli Onofri Royal Chiantishire FRRYC905SSCH Dual Fuel Range
Looking for oven element for fratelli onofri mod n13204ecs 240volt 1200watt number on part 482002
2 Suggested Answers
  • 4736 Answers
SOURCE: i just installed a new
The first thing to check is the required, inline gas shutoff valve. Is it fully ON. I know it had to be turned off to complete the conversion to LP Gas.Secondly, if you had a convertible gas regulator, was the little pin reinstalled in the proper direction. If you didn't have a convertible gas regulator, are you sure the one you changed to, is in fact for LP Gas? If not, there would be little to no gas flow. As Natural gas requires a different pressure than Propane Gas.
In addition, there may be air in the line, from when the gas was turned OFF. That air will need to be purged from the line. You can do this, by trying to continually light a burner. If after 5 minutes there's no gas. The problem may lie in an obstruction in the gas line. Check for any trash (pieces of Teflon tape, Pipe Joint Compound, etc) in the line to the cook top.
Also, if you have the equipment to do so. Check the water column inch after the regulator. It should be 11 to 13 water column inches for Propane & 7 for Natural Gas. If you don't have the equipment, contact your Propane Provider as they do have it.
Hope this helped you to further troubleshoot and solve the problem Please let me know. Thanks.
Posted on Jun 13, 2011
Has anyone had any luck finding replacement gasket? I have a Italian-made Fratelli Onofri 36"range (FREV 905S) and need to replace the oven gasket, which is broken.
Hello, Camr -
You did not state where you reside (what country.) Knowing that information will help in providing you the best source for a replacement oven door gasket.
In case you reside in the United Kingdom, you will find a replacement gasket here:
https://www.espares.co.uk/search/ma2925pt1602/cookers-and-hobs/seals/fratelli-onofri
Best wishes.
Mar 13, 2018 | Kitchen Ranges
I need a conversion kit natural gas to propane for a Fratelli Onofri range. Anyone handle parts for these in the States?
try your local propane dealer .some newer stoves do not require a kit ,as they have adjustable orifices
Aug 13, 2015 | Kitchen Ranges
Royal chiantishire buzzing how to fix
I have the same buzzing ticking clock sound much too noisy. Can't find a way to get to the clock
Mar 19, 2014 | SNK Fratelli Onofri Royal Chiantishire...
Handle loose on fratelli onofri royal chiantishire range
take off the whole door including the glass and possibly the lower shelf watch out for screws inside you can fix
Jun 19, 2012 | SNK Fratelli Onofri Royal Chiantishire...
I need the part no# for the broiler element in my kenmore easy clean oven mod C8806002190
Check out web site "Repair Clinic.com. I just looked up your model number and found several heating elements related to that model.
Jan 14, 2010 | Ovens
Install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Sep 12, 2009 | GE JTP45 Electric Double Oven
Dryer no heat
1ST YOU NEED TO SHIR YOU GET 240VOLT TO DRYER IF YOU ONLY GET 120VOLT THE LITE WILL COME ON AND IT MAY RUN. IF YOU ARE GETTING 240 THEN. UNPLUG DRYER TAKE THE LOWER PANEL AND USE A METER TO CK FOR OPEN PART ON ELEMENT OR ON T-STAT THE MUST BE CLOSE MOST PROBE LY WILL BE THE HIGTH LIMIT T--STAT OR 2ND GUS ELEMENT
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SNK Fratelli Onofri Royal Chiantishire FRRYC905SSCH Dual Fuel  Range Logo
Top SNK Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a SNK Kitchen Range Expert? Answer questions, earn points and help others
