Question about Kenmore 53301 Dehumidifier
Dehumidifier my kenmore dehumidfier stops after a few minutes with no water in the bucket. i have cleaned the air filter. if i power it off and then back on, it runs a few minutes again, then stops.
  • wallet55 Apr 26, 2008
    i did not think this was the problem for a while but as it warmed up, (and i vacuumed that small round grid on the side, though there did not seem to be anything there) the thing started working again. perhaps were were in deeper drought than i thought
  • wmkl May 30, 2008
    My Kenmore 533011 dehumdifier only works intermittently, starts only when I move it around on its castors - and sometimes not even then. Often it only runs about a minute, them shuts off.
    Novelist:
  • 184 Answers
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Posted on Apr 05, 2008
How to repair my kenmore 58054501500
ck the water catch bucket , sometimes ive seen machines stop after running a few minutes because it shook catch bucket from its perch
Jul 16, 2014 | Kenmore Dehumidifiers
My LG Dehumidfier 3850A20500H has stopped pulling moisture from the air it still runs but no wataer in the bucket what could be the problem? this starts happening after 1 year of purchase.
There are several things that can cause the problem you described. Most of which are easily remedied.
1. The humidity/moisture extraction level is set to high. Lower it to 35%
2, Air intake filter is dirty or clogged. Remove and clean the filter.
3. Refrigerant coils on the back of the unit are dirty and need to be cleaned.
4. Not enough clear air space around the unit. Maintain at least a minimum of 12" of clear air space all around the unit.
5. Unit is operating in a room that has an ambient air temperature at floor level, of between 40 -60 degrees F. Most dehumidifiers don't work well between those temperatures. Raise the unit up off the floor on to something sturdy enough for the weight of the dehumidifier when the bucket is full.
The above are the top 5 things that can cause a dehumidifier not to work properly. Fortunately, none of the solutions require any major repair to the unit.
Hope this helped you to further troubleshoot and solve the problem.
Jun 06, 2011 | LG Dehumidifiers
My dehumidifier shuts off within a few minutes of turning on. There is humidity in the air but it is not collecting any water in the bucket. I feel air being sucked in the front and blown out the back. I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Kenmore 54501 Dehumidifier
I need to know how to clean filter. Lost book
follow the below instructions:
Turn off the dehumidifier machine and unplug it from the wall.
Lift the water bucket up and out of the dehumidifier.
Locate the filter located under the compartment that houses the water bucket. Lift the filter straight up and out of the dehumidifier.
Vacuum as much of the visible dirt and debris as possible.
Fill a sink half full with water. Place the filter in the water and allow it to soak for one to two minutes.
Wipe both sides of the filter with a wet sponge to remove any remaining dirt and debris. Rinse the filter with clean water.
Wipe the filter with a dry cloth to remove excess moisture. Allow it to air dry for approximately 30 minutes before inserting it back into the dehumidifier.
Good luck.
Aug 11, 2010 | Frigidaire Dehumidifiers
Blowing fuses
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 07, 2010 | Fedders R6DH45X Dehumidifier
Dehumidifier runs, but bucket has very little water in it.
heatman101
Aug 14, 2008 | Kenmore 53301 Dehumidifier
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
Kenmore 53301 Dehumidifier Logo
395 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
