Question about HP LaserJet 2420 Printer
10.00.00 supply memory error - HP LaserJet 2420 Printer
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • HP Expert
  • 217 Answers
The 10.00.00 SUPPLIES MEMORY ERROR is based on the e-label. To clear the error, do the following:
NOTE: If the error occurs, it should appear at beginning of life, causing the error message after first installing the cartridge.
Turn the printer off and on to clear the message.
Put in the old catridge and see what happens.
If OK put in the new one again.
Verify that the print cartridge is a genuine HP cartridge.
Check that the E-label reader is functioning correctly.
Check that there is contact between the E-label chip on the print cartridge and the E-label reader on the printer.
To verify this contact, insert a new print cartridge.
Remove it again.
Check for scratches on the e-label chip and on the cartridge.
If contact is being made, replace the print cartridge (part number: Q2610A).
If contact is not being made, check the toner guides to see if they are in the proper position, or that the cartridge is not damaged.
If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
Turn the printer on again.
If the error does not clear, turn the printer off and remove tray 3.
Turn the printer on and verify if the error clears.
HP has recently discovered that a 10.00.00 Supplies Memory Error can occur when Tray 3 is faulty.
Posted on May 07, 2010
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
Supply memory error
remove the right hand side end cover ( formatter acces panel) remove the bad memory ( card about 1" by 3" )- if your not sure its failed try with new memory and see if error returns
Mar 04, 2014 | HP LaserJet M1522n MultiFunction Printer
Supply memory error
Remove cartridge, observe a small chip mounted on cartridge shell..This chip calculates the approximate toner levels, once its reached "Zero" printer says cartridge empty/low replace it.. If the memory is not detected due to any reason printer will say supply error or 10:xx supply error..
Replace this memory if available( locally its available ) or replace the cartridge.. Very few cases same error appears with faulty DC controller..
Ex supply memory:
Oct 28, 2013 | HP LaserJet P2055d Printer
Most of the laser toner cartridges comes along with the memory chip which helps to indicates the toner levels.. 10.00 supply memory error shows if memory fails/damaged/chip bad contacts/cartridge not seated properly..3_21_2013_5_19_03_pm.jpg
Mar 21, 2013 | HP LaserJet Office Equipment & Supplies
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
Hp laserjet P3005n gives memory test error when powereds
I am assuming that the printer is giving a supplies memory test error in which case it is a faulty micro chip on the toner cartridge. If this is the case then you need to replace the toner cartridge.
If the printer is not displaying supplies memory error, but actual memory test error then the problem is in the memory on the Formatter Board. The formatter board in these printers are prone to faults.
If your board has an added memory stick, I suggest that you remove it after turning off the printer and then power on again and see if the error is still displayed.
Jun 10, 2011 | Office Equipment & Supplies
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
50in samsung hd tv scrren wont turn on...red lights just keeps blinking
Change bloated caps on power supply pcb. You'll see them clear. That's should be it!
$10,00 for parts+ couple hours of labor and, you good to go!
95%. If you won't find any bloated caps, relax, it's time to get a new signal/main board. Can't fix those! Only replacement. Used one is ok.
My last case was a similar, 50" Samsung lcd panel with 4 1,000.00 mfd/16v.
good luck.!
Jan 23, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Apr 07, 2009 | HP LaserJet M1522n MultiFunction Printer
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
HP LaserJet 2420 Printer Logo
2,526 people viewed this question
Seeker5211
Seeker5211
