An 000 error on zanussi zwf14380w ,beeps,wont start and door lock symbol on, but can undo door
  • 183 Answers
SOURCE: my zanussi's door wont lock
Front PCB faulty, if you remove pcb you may be able to resolder blown track on pcb totherwise it will require replacement.common problem with this model. Regards Advisor
Posted on Aug 30, 2007
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
  • 193 Answers
SOURCE: zanussi 1200 fjs1225w.door lock clicking and door
unplug machine from power source. Lift top. check for loose wiring by removing connects one at a time and reinstalling
Posted on Oct 28, 2009
barkencoa
  • 3463 Answers
SOURCE: I have had a zanussi zwf16581g for 1 month and has
The lock symbol is indicating that the door is not locked, and until it is, the washer will not commence the programme.
Make sure you have the door fully closed, and that it is latching properly, if it still does not work, then you may have a faulty lock, or a broken spring in the door handle.
Hope this helps.
Posted on Jan 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hotpoint ultima wma61
Replace the door latch switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Power going to washing machine but wont start
The door (interlock) is likely faulty & needs to be replace.The door probably doesn't lock at all because the (interlock) is not energizing.
May 30, 2010 | Zanussi ZWF1230W Front Load Washer
I have had a zanussi zwf16581g for 1 month and has been working fine until today. Its beeping at me and a loock symbol is flashing on & off. it wont let me do anything.
Hope this helps.
Jan 09, 2010 | Zanussi Washing Machines
A key symbol has displayed on my panel and the dryer will not work. Not sure what I need to fix. opened door to take out some clothes and now it won't start up againg... beep beep and key shows
the door lock has gone it sounds to me the dryer wont work unless the door is shut so if its not picking that the door is shut then it wont work
hope that helps :)
Oct 15, 2009 | Dryers
Jan 10, 2009 | Washing Machines
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
My zanussi jet stream has power but will not start when door is closed. red light on door is not on.is there some type of door sensor that could be faulty? would appreciate any help please
probably door interlock faulty. easy part to fit.
turn of at mains. remove plastic clamp holding seal to cabinet and peel seal away in area of door lock. door lock is held in by two external screws which undo and also remove small diameter pipe fitted to door lock. undo elec connections as well. refitting is just the reverse
Oct 02, 2008 | Washing Machines
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
