Question about Keurig Special Edition B60 Coffee Maker
Special Edition B60 Coffee Maker: Coffee grounds coming up through the k cup???...
    Sniper:
  • 91 Answers
Make sure the k-cup is being punctured at the bottom... If the answer is YES... then take the K-cup holder out of the Keurig unit... verify you can put a paperclip into the needle of that piece from the inside of the shell and it comes out the bottom
that shell is actually 2 pieces and unsnaps... making it earier for you to check... once we know there is no obstruction in the bottom needle, then we need to make sure the rubber gasket in the top arm is ok... didnt come off..
the top needle that punches a hole in the k-cup, has a round rubber seal around it..
If it's not there, then it got stuck on the top of a k-cup, and you need to search the garbage for it...
in summary
clogged bottom needle
missing rubber top seal
If the rubber seal is there... hmm. while your making coffee next time....press down on the top arm... just enough to see if the ground stop... id that's the case, then we need to step back and think if we are dealing with either a bad seal, or a fatigued top arm..
My hunch is a bad seal... and possibly try to attempt to reseat it back into the arm... it cound be smashed in and needs to be coaxed back out..
Posted on May 06, 2010
Coffee grounds
Lower port plugged. Clean as per Pg. 18 manual
Oct 18, 2012 | Keurig Special Edition B60 Coffee Maker
Keurig Special edition stopped brewing
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Dec 25, 2010 | Keurig Special Edition B60 Coffee Maker
My Keurig is leaving a lot of coffee grounds in the cup
I found that the kcups were under pressure. When I insert the kcup, I press down on the cup to puncture the bottom of the cup then close it. Works fine now.
May 16, 2009 | Keurig Special Edition B60 Coffee Maker
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
537 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
