Question about Mtd LAWN MOWER PART # 903-0382 AXLE Assembly: FRONT
MTD LAWN MOWER PART # 903-0382 AXLE Assembly: FRONT: cant seem to move stick to choke or idle postion i...
Cant seem to move stick to choke or idle postion it semms to be locked
  • 2,100 Answers
You need to get some oil to drool down the cable on the inside if you can, it will free it up. Try blaster, the stuff works great. Some of the cables are just metal clad and the oil will penetrate right through it, but the plastic coated ones you have to get in from the top, hope this helps.
Posted on May 06, 2010
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
Feb 23, 2013 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
I was given a MTD push mower and I cant get it to start. Has the Honda 5.5 engine, and is stamped Aug, 09. This is the first time I have looked at it and there is no buttons labeled "Choke". ...
Try removing the air filter from the carburetor. Also, try using that white lever as a choke. There may or may not be a throttle control for it. You need to try and open the throttle on the carburetor all the way and while it is open with the air filter off, spray thru the throat with carb/choke cleaner aerosol spray so the mixture makes it into the intake maniflold. Then, try to choke it and start it. This may require a couple of people and a couple of trys, but we are trying to "force" the engine to pop and run. If it runs a few seconds on the spray, do it a couple more times. Then try to start it the conventional manner.
May 08, 2011 | Mtd 22" Yard Machine Push Mower
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Apr 14, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a model 13AH762F752 MTD Lawn Tractor on the front the bar that holds up the mower deck which way should it go in.? If you are looking at the tractor from the front R or L
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Apr 06, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Nooo parts
Find a local MTD dealer, lawn mower repair shop, they should be able to get you one. The Cub Cadet is made by MTD.
Sep 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Mtd LAWN MOWER PART # 903-0382 AXLE Assembly: FRONT Logo
67 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
