Question about CTX PL 9 19" CRT Monitor
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
My mag innovision lt716s 700p monitor screen keeps going blank but light still stays on i switch off for a few seconds and then turn back on and after a few seconds it goes off agian how do i fix
    President:
  • 1,561 Answers
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 06, 2010
Mag innovision monitor keeps turning off
It's not communicating with PC video card. It should pick up the input port, but make sure on monitor is set to correct input like VGA. You can try re-seating video card. Also test with VGA if you are using HD like HDMI.
Aug 31, 2012 | Mag Innovision Computers & Internet
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag 17
it is a problem signal cable of the monitor open the monitor test the continuty of 15 pin signal cable
if pin no 13 & 14 (hsync & vsync)are open then change the cable problem will be solved
Oct 25, 2008 | Computers & Internet
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag innovision LT716s monitor model 700p blank screen
Try to adjust the frequency.
Right click on desktop , properties, (my windows is in portugese. Dont remember the right name) configuration, button "advanced", display.
I hope to help u.
Good luck
Dec 17, 2007 | CTX PL 9 19" CRT Monitor
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
CTX PL 9 19" CRT Monitor Logo
478 people viewed this question
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Martin Murray
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
